Question about BL and tube bumpers
Old Dec 11, 2008 | 06:07 PM
eburkett's Avatar
Ok so i've been looking around for a tube bumper for the front of my tacoma and i really am getting confused. If i was to buy one now and then installed a body lift, what negative effects would this have? Because on most the sites i've looked, it shows the option to buy for if you do/dont have a BL. im lost
Old Dec 11, 2008 | 06:12 PM
SpecialScottie's Avatar
If you bought one made for no body lift and then installed the lift, you would have a gap between the bumper and the body.
Brackets can sometimes be made to correct the bumper for the body lift
Old Dec 11, 2008 | 06:15 PM
eburkett's Avatar
so its really just about looks at this point?
Old Dec 11, 2008 | 06:27 PM
sa51's Avatar
yes. and i think the gap is pretty ugly. esp on the arb bumpers. that thick upper tube also blocks the headlights when no brackets are used to keep it level to the body
Old Dec 11, 2008 | 06:30 PM
jsn_stockard's Avatar
If you can metal fab and have access to the tools you can fix the brackets to make it work
Old Dec 11, 2008 | 06:33 PM
littlecommando's Avatar
just get a suspension lift and dont worry about it, suspension lifts are better anyways
Old Dec 11, 2008 | 06:34 PM
sa51's Avatar
agreed. i wouldnt run one on mine, even though i could fit the 35s i want to stuff uner it
Old Dec 11, 2008 | 07:18 PM
eburkett's Avatar
anyone have a photo of this situation? (bl on after tube bumper)
Old Dec 11, 2008 | 07:42 PM
eburkett's Avatar
guess not lol. Anyways, anyone have reviews of diff types of body lifts, which works best. Looking for 3" of lift out of it.
Old Dec 11, 2008 | 07:50 PM
Depending on what you plan on using the vehicle for, body lifts can be a good way to lift your vehicle. You dont have to worry about any driveline angles, or longer shocks and its cheap
Suspension lifts with soft springs can even make your rubbing worse
I believe this nissan has a 2inch body lift but you get the idea of the gap
lledwod
Aug 30, 2016 01:03 PM
lectric80
Jul 29, 2015 12:25 PM
adammtb
Jul 27, 2015 11:57 AM
DrZero
18
Jul 24, 2015 11:31 PM
