Project: Save The Yota!
Old Jun 15, 2009 | 09:34 PM
Hardstripe's Avatar
updated
Old Jun 16, 2009 | 05:30 AM
Hardstripe's Avatar
You know I actually got ahold of the guy who wrote that program, he layed it all out to me pretty well and after fiddling with it- Im going to make adjustable uppers. The axle end will have 2 holes 2" apart, the frame and will have 3 holes 2" apart. Here are the numbers it gives:
These numbers are @ 2" increments of the frame end, the axle end uppers are fixed @ their lower holes.
These numbers are @ 2" increments and the axle uppers are fixed in the upper holes, 2" higher than the previous 3 pics
I liked these numbers best I may start with these first
Here is the bump and droop pics
Old Jun 16, 2009 | 05:41 AM
Squiddy's Avatar
Great work! And great thread. But Lordy, shorts + angle grinder don't mix! Git some pants on!
Old Jun 16, 2009 | 06:32 AM
yodathespian87's Avatar
Looking great. So much easier to see the big pics. Keep up the great work.
Old Jun 16, 2009 | 11:54 AM
  #25
Hardstripe's Avatar
Had the automotive engineer professor at the college look at my link calcs and pics of my fabrication, he says they look great- I asked him if my uppers axle side need to have the same width as my lowers frame side (Which someone gave me as advice)
He said its a good idea but I think with those joints you dont need to worry about binding anyways, go with what you got it looks great on the calculator.
See the red line on the last 3 pics? Its my forward thrust. Compare the end of my forward thrust in these 3 pics to the forward thrust in the rest of them. Basically you want your forward thrust to end on the front half of your vehicle, otherwise your thrust will move up, loading your tires and axle up under your vehicle. This is also where the upper link line and lower link line intersect, which goes back to how you see people recommending the links being horizontal to eachother for the lower end anti-squat. Now look at the top one of the last post. See how they are further from eachother on the frame end than the axle end? This makes the antisquat 20% but look at the instant center numbers and the lines of intersection of upper and lower arms. The arms are intersecting behind the vehicle and the instant center has negative values. The last setup has the thrust ending somewhere waaay off the graph, Has -1 degree understeer, and has a 59% anti-squat, I think it will make my rig the most capable- However I am still making the links adjustable so that when I get in and drive it I can fine tune my decision as I go.
I got the bolts in today, and I got some drill bits from a machine tool supply company- They didnt have an 18mm but I got a 23/32 and a 45/64 bit, they are as close to an 18mm as you can get. I am opting for the 45/64 first because its a little smaller than 18mm vs the 23/32 which is a little larger.
The decimals for each are:
45/64 = .7031
18mm = .7087
23/32 = .7188
Pretty damn close, Think it will work?
Ill take pics
Old Jun 16, 2009 | 09:31 PM
  #26
Hardstripe's Avatar
updated
Old Jun 16, 2009 | 09:45 PM
  #27
CRafferty's Avatar
God, that right there is some AWESOME work. Great job on the build so far man.
Old Jun 16, 2009 | 10:06 PM
  #28
weaselman's Avatar
awesome work man. looks great
Old Jun 28, 2009 | 10:57 PM
  #29
Hardstripe's Avatar
updated
Old Jun 29, 2009 | 08:08 PM
  #30
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Man I dont want to go searching around for your updates.... ugghh
Old Jun 29, 2009 | 08:58 PM
  #31
Hardstripe's Avatar
umm... its the bottom of the first post, whats to search?
Old Jun 30, 2009 | 03:38 AM
  #32
flashkl's Avatar
That is the epitome of laziness... lol
Old Aug 5, 2009 | 12:03 PM
  #33
Hardstripe's Avatar
more to come
updates are coming soon!
Old Aug 5, 2009 | 03:10 PM
  #34
flashkl's Avatar
Cant wait...
Old Aug 8, 2009 | 12:04 AM
  #35
Hardstripe's Avatar
updates
updated! see last portion of first post
Old Aug 8, 2009 | 12:19 AM
  #36
Fink's Avatar
Where have I been and how did I miss this??
Subscribed for sure.
This thread is the definition of a DIY'er.
Fink
Old Aug 8, 2009 | 05:12 AM
  #37
flashkl's Avatar
How old are you? Also, why aren't you my next door neighbor??
Old Aug 8, 2009 | 07:10 AM
  #38
92 TOY's Avatar
Ditto!
Nice work man!
Old Aug 8, 2009 | 08:27 AM
  #39
RaginYota's Avatar
Nice work so far... can't wait to see the final product.
Old Aug 8, 2009 | 08:32 AM
  #40
RaginYota's Avatar
I also had hired help.. but she was an expert on SFA..lol... It was great she had the perfect size hands for greasing inside the knuckle.. If anyone needs help I have her contact info, and it will cost a package of double stuffed oreo's and some milk..lol
