Offroad Trailer Build PArt Deux
Old Jul 10, 2010 | 03:42 PM
DanStew's Avatar
Well I guess I am just needing something to do
Decided i had enoghu metal laying around that I should make another trailer to help me get trash to the dump.
this
Plus This
Equals This
I had an old cabinet at work that i cut the rear bottom portion off so i commandeered it to be my body tub. At first i was going to keep the box as is for the sides and hack the rear off, but i am gonig to cut the sides down a bit and do it like my other trailer. It will have a tailgate and will have a pintle for the front and for the axle i am going with a 6 lug axle setup to match the yota. Lets see how long i keep this one.
I hope to get the frame done tomorrow and the springs hung, then cut into the tub. After that i jsut have to save for the trailer axle stubs,hubs and pintle. The trailer is going to be be 3 feet wide, 5 foot long and about 14 inches tal (tub)
Old Jul 10, 2010 | 04:17 PM
muddpigg's Avatar
Nice and a good idea. Stout frame. Same width axle/footprint as your rig?
Old Jul 10, 2010 | 04:26 PM
DanStew's Avatar
IT may be a bit skiniier than the rigs width. But close.
Old Jul 10, 2010 | 08:19 PM
muddpigg's Avatar
Do you think it necessary to run gussets to the outside inner corners? Why the pintle hitch with the length of a wall locker?
Not busting your chops just curious.
Old Jul 11, 2010 | 04:26 AM
DanStew's Avatar
I am not nearly finished with the frame yet, it is only tacked toggether. There is going to be two gussets in the front, connecting the center to the side rails of the frame.
It will end up like this frame, just differnt materials.
I just like the pintle. Simple and rugged. It is noisy but i can live with it.
Here is my first trailer i did about 2 years ago.
Old Jul 11, 2010 | 06:05 AM
clydehatchet's Avatar
I like that box on the last picture. where did you get that?
Old Jul 11, 2010 | 06:10 AM
DanStew's Avatar
I made it. Decided to save myself some fab time by using something already bent up. That yellow trailer took a bit of fab work since i didnt have a sheetmetal brake, it was bent up with a hammer.
Old Jul 11, 2010 | 07:23 AM
BigBluePile's Avatar
Nice man!!! Probably a lot lighter than my use to be a truck trailer!
Old Jul 11, 2010 | 11:50 AM
muddpigg's Avatar
Really nice work.
Old Jul 12, 2010 | 12:27 PM
DanStew's Avatar
A bit more is done. Pretty much finished the frame except for the front pintle loop and i have to make a landing leg for it. I am going to start on the tub. After that it may slow till i can get $$ together to buy the axle parts. All this stuff is things i had laying around. And i still need bolts for the shackles and spring mount, i threw some longer bolts i had to mock it up.
Old Jul 12, 2010 | 12:30 PM
Fink's Avatar
Subscribed.
Fink
Old Jul 16, 2010 | 06:37 PM
DanStew's Avatar
Got some more done tonight. I cut out the top where the doors hung and got some conduit to strengthen and trim the walls of the tub. I clamped the conduit to the sheetmetal and with a hammer I went around and hammered the lip of the sheetmetal to the conduit and welded it. Didnt take long at all to get it into shape.
Here is the one ugly spot i have, i had to patch a large section of the floor from where i cut out this cabinet a while ago. just tedious. In the end you will see it as being filled but i am not too worried bout it, it is a trailer that will haul stuff. I plan on putting a piece of plywood on the bottom to make the floor a little more durable.
Looking back on the last trailer build this one was much less hammering since i didnt have to make the walls of the tub from scratch.
Old Jul 16, 2010 | 06:52 PM
Are you making this trailer to haul around all that cat litter?
Old Jul 16, 2010 | 06:55 PM
DanStew's Avatar
HEHEHEHEHE God knows they go throguh enough. They make great storage bins for misc parts and such.
Old Jul 16, 2010 | 06:58 PM
also used oil...... i have cats too. on the bright side, i drive a yota.
Old Jul 16, 2010 | 08:08 PM
morena67's Avatar
Nice work...
Old Aug 10, 2010 | 09:06 AM
irab88's Avatar
any progress?
Old Aug 10, 2010 | 10:33 AM
DanStew's Avatar
i havnt touched it in a few weeks. actually will try to get on with it this week.. hopefully.
Old Aug 10, 2010 | 08:40 PM
irab88's Avatar
great job so far. idea: what if you put some brackets on the front or sides to hold some kitty clay boxes? (sorry, 100 mile commutes a day give me time to think about random stuff. watch out)
edit- great welding, by the way. what kind of welder do you have?
Old Aug 11, 2010 | 03:43 AM
DanStew's Avatar
I am using a my old 110v campbell hausefeld mig for the tub and a 220 stick welder for the frame. i may jsut fill up the trailer with kitty clay and have a mobile cat facility hehehe
