The "Official" 3rd Gen Gas Tank Relocation Thread!
Old Apr 24, 2005 | 07:57 PM
  #101
ravencr's Avatar
Today I fabbed up the the rearmost support that attached to the crossmember I had built a long time ago. I've decided to cut down the skid plate to 27 3/4" and angle up the sides, so I've still got quite a bit of stuff to do on it yet.
Chris
Old Apr 24, 2005 | 09:54 PM
  #102
RTdawgs's Avatar
<-------- Golf claps. Looks excellent!
Old May 19, 2005 | 12:37 PM
  #103
ravencr's Avatar
It's finished and trail tested at Tellico. It passed with flying colors! Hopefully I'll get some pics up soon.
Seaflea might even have a better tank for us to use on the next go around that's out of a mustang.
Stay tuned for his buildup!
Chris
Old Sep 10, 2005 | 02:22 PM
  #104
green91runner's Avatar
*bump*
Old Sep 11, 2005 | 05:26 AM
  #105
seaflea's Avatar
look on page 4 of this thread
Old Sep 11, 2005 | 07:14 AM
  #106
i seen those pics.. but i was talking about his last post... wanted to see the skid plate setup... doesn't really matter.
Old Sep 12, 2005 | 05:04 AM
  #107
ravencr's Avatar
I'm sorry man! I'll get some pics to you soon,
Chris
Old Oct 5, 2005 | 07:16 AM
  #108
ravencr's Avatar
Stay tuned for some more pics tonight, hopefully. I should have some before and after pics of the new front crossmember. I've decided not to use the FROR crossmember for now, and simply use a short 6" piece of 3x2x3/16" tubing, and 2.5' of 3x1.5x3/16 tubing, which will result in the bottom of the new crossmember being 1/2" above the frame rails.
I'll also take some final pictures of the gas tank/gas tank skid too.
Chris
Old Oct 6, 2005 | 10:29 PM
  #109
ravencr's Avatar
Here they are, completely flat undercarriage at least all the way back to the lower control arm frame mounts. Those will eventually be gone too, but too many projects before that happens.
Not great pictures being that it was in my garage, but it gives you an idea, at least.
Chris
Old Feb 5, 2006 | 04:24 PM
  #110
Hyperlite's Avatar
looks good chris, here is the set up I have been running for a couple of months. I modified the factory sender and userd it so the factory pump, gauge and the light work. Kinda loose some space and smells like gas but it works
Old Feb 5, 2006 | 05:22 PM
  #111
ravencr's Avatar
Just be careful leaving the windows up if you're smelling gas. sounds dangerous to me!
Chris
Old Feb 5, 2006 | 05:31 PM
  #112
Hyperlite's Avatar
I leave my back window cracked at least 2 inches and all my side windows down about vent shade height. I don't have carpets and my drain plugs are all pulled in the cargo area. It only smells after I fill up now. btw now people are scared to smoke in my unit.....
Old Feb 5, 2006 | 05:39 PM
  #113
ravencr's Avatar
That's not such a bad problem. It definitely is the optimum setup for clearance, that's for sure.
Chris
Old Mar 9, 2007 | 04:44 AM
  #114
ravencr's Avatar
Yeah, I'll have to do it this weekend.
Chris
Old Mar 9, 2007 | 07:36 PM
  #115
Sean K.'s Avatar
Chris
Thanks! I'd appreciate being able to see them too. Your set up sounds like it was awesome!
Sean
Old Mar 26, 2007 | 01:37 PM
  #116
ravencr's Avatar
I'm sorry guys. I started to get them back up, and then got sidetracked. Can you email me at chris@utvrally.com and I'll probably just email them to you to save me some time.
Chris
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
jerusry
Oct 19, 2015 05:28 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
