an odd question (rock sliders)
Old Jan 30, 2013 | 03:33 PM
20ozjolt's Avatar
so I'm planing on building some here shortly, i was going to go with square stock...
here is the question: would it be doable to mount 4 2" pieces of tube on the out side surface pointed up to act as receivers for a removable door / side guard?
this has been in my head for a while....
Old Jan 31, 2013 | 09:07 PM
rustytaco's Avatar
It could be done have you thought of just getting or building a set of tube doors
Old Jan 31, 2013 | 10:12 PM
nothingbetter's Avatar
of course its do able. Why not build them without then weld them on later if you decide you so desire. sounds akward looking to me. And would hey interfere with the door opening? snagging your feet when getting in?
Old Feb 1, 2013 | 06:25 AM
waskillywabbit's Avatar
Sounds like a door damage multiplier to me with only bottom bracing.
:wabbit2:
Old Feb 1, 2013 | 05:50 PM
MGTexas's Avatar
I'm thinking that there will not be much protective value above the corner and no way to improve that protective strength without side bracing, unless you go exo.
Mike
Old Feb 4, 2013 | 03:51 PM
20ozjolt's Avatar
the lat two are what I was worried about. and yes the would block the doors... that's why they would be removable... on trail only.
@ web, me no structural engineer, and it being a big old lever welded to my frame... hence checking with y`all.
@ MG, even with exo (it looks like) most exo's lack cross bracing, i would want to move the bed away from the cab 4" and add a X there...
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
priest16
15
Aug 6, 2015 07:43 AM
coryc85
Jul 6, 2015 04:07 AM
