Need pics or designs to build tube bumpers
I sure hope you're not talking about welding low grade pipe to a CAST elbow! Thank god it's only a bumper, cause that's piss poor advice safety-wise...
Well figured it was coming, but... The sliders on my truck are made of the same stuff, Cast does not weld like normal steel. Weld elbows are made of the same stuff as the pipe. I dont think cast can even weld by arc. I think it has to be cooked. Thats why sprinklers are threaded and coupled. The sliders have done very well. Did the high lift test one em too ( raise up about 3 foot and drive off on a rock, no dents or twisting)
Guess what, the old guy is wrong. Pound for pound (as in similar wall thickness) structural tubing is much stronger than pipe.
Structual tubing is bored correct? So the old man told me, Not welded seam, that would make it stronger, and costly. Cant affored bored tube here
Actually it would be 4.7625mm,
Oh yeah for got 2.54 thing opps, meant hundredths
to preheat or cool the tubing, if you're a competent welder it will hold up just fine
Learned the cooling thing from an old welder who welded Nuclear, Hasent fallen out yet
But thanks for the other lessons, learned bunch thanks
Originally Posted by sportJr
Structual tubing is bored correct? Not welded seam
Oh yeah not a competent welder either, just a rod burner
#25
Originally Posted by Serith
Hey BigBadBlue
Let me know how that works. i was looking at the exact same one, so let me know. Thanks
#26
You're comparing apples and oranges man, 4wheeling isn't rocket science. Just because he can build a reactor cooling system doesn't mean he can build a safe roll cage.
Not quite where I was going with that really, He is a Certifed welder, Needed to weld on the Nuke projects, he was just saying to have a more flexable weld, you cool it slow. It is a good idea for roll cages just for the fact that a strong blow will bend and not snap. He was just giving me some pointers when I was doing my sliders.
#27
BigBadBlue,
give me a date, and i'll consider it, depending on how things go, school and work. i know you guys are just kinda wingin it, but a rough date would be nice, im gonna try to join you at reiter.
#28
BigBadBlue,
#29
Anymore designs/pics for a 2nd generation front bumper?? I have found someone who fabbed a bumper for his 2wd and it looks awesome. Any ideas would be great (I promise not to steal them, just looking for comparisons to my own ideas.) Thanks!
:walk:
:walk:
#30
Guest
Posts: n/a
If you have a bender, I hear (pirate 4x4) that this software is pretty good.
http://www.2020softwaresolutions.com/index.htm
They have 70 or so templates, a material library, and lots of other cool functions.
DrZero
18
07-24-2015 11:31 PM
