My Home Built Center Console
The levers are as follows from the driver to the pass:
5:1, 2.28:1, 4wd, trans.
Due to the linkage all the shifts are opposite of stock.
Heres the frame
Here it is during construction, the seat is blocking the most of the linkage (heims) I have to pop the side panel off to hook up the cable for the trans, so ill snap a shot of that
I always wanted to make a custom console and I love supra consoles and early viper consoles so.......
Oh and under the cb speaker there are 2 tiny light bulbs on a switch that will aid me in seeing which gear im in (since the B&M doesnt have gates) at night and night wheeling.They have a little cover over them to protect them and so they dont bother the driver.
#25
#29
#30
Yup I can selest any gear and any torque converter configuration. Any one who has driven the auto knows that it is shift happy and shifts at the wrong time. I dont really use it off road, but i might now with the duals
#35
Hi,
What did you do for boots? I've my custom auto shifter working perfect but I need something to cover the hole... No duals thought.
The problem is that the auto shifter only goes FF-RR but in a wide motion while the T-Case lever has less movement but in all directions...
David
David
#37
Hi,
David
David
For you I think I would put a nice compact boot on the t-case shifter and a plate like mine for the auto stick. But since my "boot" doesnt actually protect the interior from the elements I would do something different for yours. Maybe heavy rubber. Or a slide like the stock shifter, install a piece of metal/plastic under the plate and have the shifter go through it so it would slide as the shifter moved....
Or make/buy a cable shifter and call it done (Art carr, locar, B&M...) Mine is a B&M (it was free) I just gutted all the ratcheting crap and just use it as a lever.
#38
Thanks, I thought about that you mention. I'll try the leather/rubber with a cut method or will try to get a twin-stick boot.
I wanted to make a custom twin-stick but I had the idea after the T-Case was bolted to the tranny so it will stay like that.
I'm going to make a custom console similar to yours but not so high. Your's is an inspiration.
David
David
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
terminator
Jul 27, 2015 07:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
HookahRoo
Jul 20, 2015 07:06 PM
that is a pretty sick looking set-up. very nice work. you need some stickers on it.
