My 2nd Gen 4Runner Buildup. SAS, Duel E-Lockers, Full Exo and more…
#103
Originally Posted by waskillywabbit
Looking good! You gonna leave all those extra brackets on there? I'd hack any you don't use for something OFF...one less thing for the rocks to grab!
#104
Here are some pictures of how I left the axle tonight. The E-locker is not installed nor the axles. I’m waiting on the lockers to be re-geared. The plan is to just get the axle huge then add the e-locker and 30 spline longs later.
#109
THE SAS IS COMPLETE!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Well almost.
Here are a couple of the pictures I took with my camera. Marc (zman2day) took a lot with his camera so I’ll get them from him and have them up later.
Before I post these pictures I’d like to publicly thank both Marc (zman2day) and my brother (Matt) for there help. I couldn’t have finish this part of my buildup without there help, so I say “Thank you” to them.
Here’s a couple before SAS pictures.
IFS parts.
Here are some poser flex pictures. These springs don’t flex very well, there just cheap old stock 3” lift springs that we used to get me home. I’m still trying to decide on some Trail-Gear springs or a custom Toyota rear pack.
I still need a drive shaft, some inner axles, and an E-Locker.
Onward to the 3.4 swap.
IFS parts.
#110
I’ll start another buildup thread for this later but I found a rebuild-able 22RTE for my 1992 daily driver pick-up. My goal is to have that motor push around 180-200HP or so; I think stock is 160 or something. I’m going to pick that motor up next weekend and start rebuilding it in a week or so.
I need to do some research on it. Does anyone know how much work it is to swap a turbo motor into a non-turbo truck?
#111
#112
Originally Posted by rockota
EDIT: Missed the "T" in that. Sorry - my bad. 145HP stock. 200HP will cost some $$.
I realize the 180-200HP number was way high now that I've done some reading.
#114
Originally Posted by zman2day
I put the pics on CD before you left.... did you loose it?? I can try to post if needed....... Good Times this weekend... BTW got the feeder workin on the welder again...
#116
that new motor and a re-solder to the main board.
.I found an HP E-locker in GA. I’m going to call them about it tomorrow.
#118
Bring it on..... the welder is warmed up and ready....
BTW.. I got that extra set of leafs at the house.
BTW.. I got that extra set of leafs at the house.I’ve been thinking about ordering both front and rear springs from Trail-Gear. Give me a weekend you’d like to do the rear and I’m there. I’ll put the order in to Trail-Gear ASAP
#120
It’s official. My 3.4 swap is under way and in the parts gathering stage. I’ve posted my 3.0 motor and trans for sale to try and help with some of the cost.
Man, that's gonna be one bad rig come May! Is there gonna be a test run before then? If so, I'm in!
