Lets see those Custom mud flaps pics
Old Oct 25, 2008 | 10:12 AM
bikerbob's Avatar
bump for the weekend crowd
Old Oct 25, 2008 | 12:39 PM
4rnnr33's Avatar
what i would do is attach the mud flap to a piece of 1x1 square and weld a piece of square with a 1" i.d. to the frame and drill a hole through both pieces of square so that you can slide the 1x1 picece into the piece welded to the frame and stick a pin to hold them together and have quick release mud flaps. if that makes any sense.
Old Oct 25, 2008 | 01:01 PM
4rnnr33's Avatar
like this
Old Oct 25, 2008 | 01:05 PM
4Crawler's Avatar
Originally Posted by bikerbob
I have read the write up 4crawler did. I like his idea but they are not big enough and they are only for the rear. I had to take off my front ones so my tire will clear and so I now have to replace them too. I don't think his idea will work for the front because I am going to have to mount the mud flaps behind the front wheel well so my tires can clear.
Same idea will work for the front flaps and some day I hope to have a pair to install. You just need to make some pieces of metal to run up to the body mount bracket to attach the upper cross piece to. Then the flap can just slide into that and be pinned in place. Actually for the front pair, I am planning to use round tubing instead of the channel. The tube will be slit along the bottom side. Then the mud flap will go into a round piece of aluminum into which a slot is cut. The tube will then attach to the frame with a pipe flange.
Old Oct 25, 2008 | 06:39 PM
  #25
rhale's Avatar
this is what i had done at the local shop. they just took some thick semi flaps and cut them down and welded to the frame. its fast and easy. but still freaking ugly. i hate that utah requires these.
Attached Thumbnails Lets see those Custom mud flaps pics-dsc00709.jpg   Lets see those Custom mud flaps pics-dsc00710.jpg
Old Oct 25, 2008 | 06:42 PM
  #26
4banginRunner's Avatar
Old Oct 26, 2008 | 07:53 PM
  #27
88wildrunner's Avatar
nice pics of mud flaps guys, i currently have a fix it ticket for not having any. the mounts i made for the mud flaps ripped off on my last rubicon trip.
once i saw a guy with 39's on his toyota and he had tiny stock jeep mud flaps on and they said jeep on them which was pretty funny.
Old Oct 27, 2008 | 09:59 AM
  #28
Yellowtruck's Avatar
[IMG][/IMG]
Old Sep 26, 2010 | 08:28 PM
  #29
87hillbillyoter's Avatar
bump i just got a fix it ticket for these lets see some more!
Old Sep 26, 2010 | 08:38 PM
  #30
yota864x4's Avatar
Mine are just thicker, longer, wider mudflaps bolted to the stock? brackets. I can get a pic tomorrow if anybody wants one
Old Sep 26, 2010 | 10:52 PM
  #31
DROPT's Avatar
Old Oct 2, 2010 | 05:11 PM
  #32
norcal93's Avatar
My old 85, keepin it legal.
Old Oct 3, 2010 | 06:51 PM
  #33
poweraid's Avatar
I used snowmobile tracks on one of my old trucks: )
I cut them up so they would skiff the ground lol
Old Oct 4, 2010 | 06:11 AM
  #34
habanero's Avatar
Using 92 TOY's idea...
I've stuffed tires into them more than a few times and so far they're holding up nicely and doing a great job.
Old Oct 4, 2010 | 06:18 AM
  #35
dropzone's Avatar
Fossilized
got some quick release mudflaps mounts made:
came out a little closer to the tire than I thought...not a good idea to mount them w/o mudflaps..I will get some material to use as a spacer to gain a little more clearance with the tire....
Old Oct 6, 2010 | 04:42 AM
  #36
norcal93's Avatar
I like the quick release idea, looks very easy to use. Wouldn't have to be fumbling around too bad after a days of wheeling.
Old Oct 11, 2010 | 07:17 PM
  #37
drew303's Avatar
quick disconnects (the bolts were just temp till i made it to Lowes for the banana clips)
I gotta find a better flap though, these royally suck. The rubber cracks and rips and I've had them fall off twice now.. not including all the times ive gotten lazy and not taken them off and ripped them off wheeling haha.. but really, the rubber is really brittle I just re-attached them again this afternoon.
Old Oct 11, 2010 | 10:19 PM
  #38
DeathSycthe02's Avatar
dont need front mud flaps ha....
Old Oct 24, 2010 | 12:12 PM
  #39
LouieLumberjack's Avatar
does it matter if its earlier than a 90's truck? I have an 82 and cant find any that will fit it. Is there a place to buy them online or something?
Old Oct 27, 2010 | 11:12 PM
  #40
894x4#476's Avatar
On my 89 with the flatbed i just bought the guy before me just used roofing membrane for the flaps. lol its really ugly and at 20 mph they fly up and everywhere...so im gonna fab something up next weekend i think when i make it home again and ill post a pic or two. theyre definately gonna be quick release.
