Homemade shackles
Old Mar 24, 2011 | 09:48 PM
4x4jeffyota's Avatar
Homemade shackles
I got bored at work today and made some 8'' shackle for my 86 pickups saggy rear. Now before I put em on is there any serious reasons why I shouldnt use them? thanks
Old Mar 25, 2011 | 03:08 AM
91 4Runner's Avatar
Only the thickness of the material that you used... If it's thick enough then no. Pictures would help.
Old Mar 25, 2011 | 04:47 AM
waskillywabbit's Avatar
Pics before judgement
My gut says "Darwin"
:wabbit2:
Old Mar 25, 2011 | 07:35 AM
im trying to get some pics uploaded right now with my phone but its not working and my camera is messed up, but im still trying. The shackles are 1/8 thick. I was going to install them and have my brother bounce up and down on the bed and see if they bend any, if I have too i can box them in with some more steel.
Old Mar 25, 2011 | 07:41 AM
justin_4runner's Avatar
1/8 is a little thin... i would box or get thicker stuff.
Old Mar 25, 2011 | 07:46 AM
WAAAAY too thin at 1/8" thick.
3/8" thick or more for something that long and braced too.
:wabbit2:
Old Mar 25, 2011 | 08:16 AM
corax's Avatar
$15 and I'd guesstimate ~1/4" thick
Old Mar 25, 2011 | 09:17 AM
I've seen those at autozone
Old Mar 25, 2011 | 09:18 AM
here is pic Name:  195914_1932392631941_1306020030_2373819_1627661_n.jpg
Old Mar 25, 2011 | 09:39 AM
blake.nemitz's Avatar
those are pretty thin i would go thicker or stack two together and weld to make a 1/4 thick one
Old Mar 25, 2011 | 09:41 AM
im sorry they are 3/8 not 1/8, my fault
Old Mar 26, 2011 | 03:12 AM
91 4Runner's Avatar
Can we get a picture with a tape measure showing the thickness? They don't look like 3/8" from this angle...
If they are 3/8" brace them with a cross tube just wider than the spring eye...(just enough to install them - make them look like a large capital H) If they are 1/8" I wouldn't use them.
Old Mar 26, 2011 | 08:16 AM
PadgettFabrication's Avatar
First of All, if I were building a set of 8" tall shackles, I think I would use 3/8" thick, if shackle bolts were found long enough, and I would definatelyweld in a section of preferrably rectangular tubing between the two plate. 8" is pretty tall and the potential for sideshift and the resulting catastrophic failure is high..
Originally Posted by 4x4jeffyota
here is pic
Old Mar 26, 2011 | 08:33 AM
RMA's Avatar
RMA
those look like 1/8 not 3/8.. dont use them .. you need some thicker ones ..
or just tell us what streets you use so we can stay away!
Old Mar 26, 2011 | 09:00 AM
they do look thin on that table but they are 3/8, im going to go ahead and box them in to make em stiffer
Old Mar 26, 2011 | 05:00 PM
dark_fairytales's Avatar
looks like a nightmare too me. Surly needs more cutting and welding.
Old Mar 27, 2011 | 07:52 AM
yea, im just gonna double em up i guess
Old Mar 29, 2011 | 09:49 PM
peow130's Avatar
if they're 3/8ths you dont need to..
go measure them.
Old Mar 29, 2011 | 10:37 PM
i measured them, they're 3/8 I promise haha. So you think 3/8 is thick enough to hold the weight?
Old Mar 29, 2011 | 10:56 PM
peow130's Avatar
3/8ths is plenty, but just do a middle crossbrace.
Obviously 8" shackles arent going to fix the sag in the long run.
In fact, they'll make your springs worse...
They'll go into a negative arch and the ride will be worse.
