Homemade 4runner bumper...
Old Jul 14, 2011 | 07:57 AM
  #41
dlucky894runner's Avatar
Ya, I don't know what I'll do. We'll just have to see how much noise they make and such. I may end up cutting them off and going with a shackle set up instead. We'll see.
Old Jul 14, 2011 | 08:31 AM
  #42
irab88's Avatar
Originally Posted by Teuf
All that work and then use a bunjee cord? Nah that will look like crap.
i guess i should have specified. i don't mean the colorful ones you buy at the dollar store, but rather a semi-permanent setup. attach one end under the frame, and make a nicer looking hook to go around the ring. and i don't think it'll look too bad with the black ribbon type cords, either
(imho)
Old Jul 14, 2011 | 12:19 PM
  #43
vang_22re's Avatar
you should add on a tire swing out
Old Jul 14, 2011 | 12:20 PM
  #44
Here are some progress shots of the boxing in.
Granted. I do have some major cleaning up to do, but hey, its a start.
Old Jul 14, 2011 | 12:22 PM
  #45
I might look at that down the road, but I really like the simplicity of this one. I also thought I might add some side panel protection, as well. Who knows...
Old Jul 14, 2011 | 03:24 PM
  #46
Philbert's Avatar
+1 on the swing out carrier...that would be badass
You could make it simple and even removable (modular) if you didn't want to always use it.....
Old Jul 14, 2011 | 03:51 PM
  #47
87 Deathtrap's Avatar
Subscribed. I hope to build something just like this for my 4runner! Great job!
Old Jul 14, 2011 | 08:33 PM
  #48
The Ruckus's Avatar
I wonder if there's something like the maglite mounting clip that you could bolt up to the bumper to hold the d-rings in place. Something along these lines
Or really, let it hang down. Drill a small hole above and below the ring where it lands. Black zip ties.
Old Jul 14, 2011 | 09:28 PM
  #49
twistedyota's Avatar
looks good
Old Jul 14, 2011 | 09:39 PM
  #50
Philbert's Avatar
How about using strong magnets?
Old Jul 14, 2011 | 11:35 PM
  #51
I had clevis rings on my last rig and used a bead of black rtv where they smacked the bumper. It worked for me.
Old Jul 15, 2011 | 08:00 AM
  #52
Great hint. I'll look at that.
So, next question? What to paint it? I know powder coating would be better, but I am on a budget of $0, so....? Spray Bed liner? Rustoliem Flat black paint? Florescent Green, for an accent color? What do you all think?
Old Jul 15, 2011 | 08:04 AM
  #53
irab88's Avatar
rustolium hammered is my suggestion. it's easy to touch-up, too
also, this stuff. goes on clear
Old Jul 15, 2011 | 02:16 PM
  #54
x2 on the rustolium hammered. I used it on my current diving board of a bumper and couldn't be happier. It's pretty tough and, like irab said, easy to touch up. Several colors available as well.
Old Jul 15, 2011 | 09:38 PM
  #55
I got some time to work on my bumper a bit today. Here are some pix.
Still have the D-rings to weld on, figure out mounting brackets and Paint.
Old Jul 16, 2011 | 07:11 AM
  #56
irab88's Avatar
oh, just one thing on the hitch: i don't know about your state, but here in va, if you want to tow a trailer you'll need safety chains. just a thought that you might want to add some loops behind the bumper on either side of the hitch
Old Jul 16, 2011 | 12:40 PM
  #57
Ya, that is in the plan. I just hadn't decided on how to do it. Or what to do. Thanks for the drawing. That is what I ink I'll do.
Old Jul 19, 2011 | 05:50 PM
  #58
Updates....
I had some time today, so this is what I got done...
Pic of the D-link I went with...
What are some opinions as to how close it should be? I like being able to step on it to get in the back, but it looks a little far out. I think I may have to go and cut my mounts back a little more... I still need to add safety chain mounts, do some clean up, primer and paint it.
Old Jul 19, 2011 | 06:28 PM
  #59
irab88's Avatar
my suggestion, now that you mention it, is to add a plate on top that extends to the body (not touching, but just there to fill the void). i can draw it up later tonight if you want
something like this» []¯
Old Jul 22, 2011 | 06:06 AM
  #60
I looked at that, but I really like the look of the tubeness of the bumper as it sits.
