hanging rear shocks first timer
Old Feb 11, 2013 | 06:04 PM
Zpd426's Avatar
Ive got some fox 2.5 11.5" travel internal bypasses off of a Ford Raptor and im going to put them on the rear of my t100. Right now ive got 12" travel in the front and a mini deaver pack on the rear with 10" 5150s
Any tips on getting the shocks in the right vertical spot so I get my full travel and dont bottom the shock too soon? (I may lay them back or tilt them in only as much as I need to make them fit)
My first idea: Should I use the bottom of my current 5150s shock body as a reference point, maybe measure from the frame to the bottom of the shock body?
Second Idea... just read this
4X4REVIEW.COM: Be A Genius - Shock Absorbers
I dont have bump stops.. they were removed long ago for a set of airbags. Should I take off my shocks and start with installing some bump stops?
Thanks
Old Feb 11, 2013 | 06:08 PM
rattlewagon's Avatar
Flex the rear end out and measure the full droop and compression of the springs, then place your shocks accordingly.
Old Feb 11, 2013 | 06:41 PM
niall's Avatar
To get the best performance out of a set of shocks, you want them mounted as far outboard on the axle as possible, as well as being as close to vertical as possible.
Old Feb 11, 2013 | 10:20 PM
Zpd426's Avatar
Ya but I need specific techniques and reference points to measure from etc, like a walkthrough to get the geometry right
Old Feb 11, 2013 | 10:54 PM
niall's Avatar
Very few setups are identical. Walkthroughs are tough because of that. Like I said. Mount them as far outward as possible, with as little lean as is necessary, build mounts, limit droop if necessary.
sandyota
Feb 4, 2021 11:16 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
ddg71
Jul 24, 2015 01:24 PM
Massmayhem247
Jul 18, 2015 05:46 AM
