Full size running gear under 87 pickup
Old Feb 28, 2007 | 06:19 PM
vwfastg60's Avatar
Im looking in to swapping full size axles under my truck and the only thing i havent figured out is what driveshaft to use or is there an adapter to get?
Old Mar 1, 2007 | 05:16 PM
Jackedupyoter's Avatar
I'm going to start the same swap this weekend, I'm just going to have mine made.
Old Mar 1, 2007 | 07:55 PM
all_terrain17's Avatar
Could always build some square shafts...
http://www.pirate4x4.com/forum/showthread.php?t=90517
Old Mar 1, 2007 | 10:19 PM
vwfastg60's Avatar
The truck is still my DD well 75% of the time but i would rather not mess with the square shafts.
Old Mar 1, 2007 | 11:53 PM
DudeBud's Avatar
dd with full size axles damn wish we could do that around here and not get harassed by the police about the width. what axles are you going to be using?
Old Mar 2, 2007 | 12:17 AM
UKMyers's Avatar
Better question for the Pirate crowd.. I'd do some searching first before you just ask though.
Old Mar 2, 2007 | 07:36 AM
AxleIke's Avatar
you don't need to ask over there...there are about 100 threads with full width buildups with leafs, coils, coilvers, airshocks etc...Just search around.
Old Mar 2, 2007 | 09:13 AM
Flygtenstein's Avatar
All you need are pinion flanges for whatever axles you have that adapt to Toyota driveshafts.
These are commonly available from High Angle Driveline for both 44's and 60's.
Would someone explain how building a square shaft would aleviate the problem? I am pretty sure that is like telling the guy to buy an elephant.
There is nothing special about these axles in front other than spring perch width, full width axles are in the 31" pin to pin range. Toyota is 29ish. Combine that with brakes and you are good to go.
Old Mar 4, 2007 | 01:35 AM
vwfastg60's Avatar
ok i will do some hunting. It will be a D44 in the front and a 14bolt FF rear. My buddys doing up the steering and the links. I just have to work out the driveshaft issue and the coils.
Colorado seems to be pretty lax on this. My buddy has the bed off his S10 and 3/4ton driveline in it no bed all cage and has yet to be pulled over.
Team420
Jan 12, 2021 04:57 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
crash
Jul 19, 2002 08:35 AM
Corey
24
Jul 15, 2002 07:53 PM
