flatbed and shock rear shock mount
Originally Posted by 934rnr
I'll take a peice of 3/16" steel and shim the rear mount for ya the next time you see it. Jeezh...
RJ and I did some mods to the flatbed today but we ran out of wire.
We will finish it up tomorrow when I have a fresh spool of .030.
I am keeping it a secret until I am done with it.
#25
Notice anything different?
I used the old smittybuilt rollbar and cut the legs off and used peices of 1/4" 5x5 boxed to stand the roll bar on welded the roll bar to the peices then welded it to the flatbed.
I plan on adding some support legs from the roll bar to the frame but I am waiting until I have my rocksliders done to do it.
I know it's not some sick ass exo setup but it's basic protection if I do roll over.
#26
Just some info I just completed my 2000 silverado 63" leaf spring install tonight.
The front spring bushing has a 5/8" diameter bolt hole so you will need to drill your spring hanger to match.
The rear leaf bushing is still 9/16" so that hasn't changed.
Also the center pin on the leaf pack is a little larger than 5/8" so the ubolt plate center hole will need to be reamed out slightly to fit.
The 00 silverado pack I am using is a 2 leaf pack with a overload.
I am using bud built 8" shackles and the spring pack makes the truck sit level with the front and I believe the front springs are 4" procomp springs they have sagged some and are actually about 3" now.
I am able to completely stuff my rear tires they touch my flatbed tray.
#29
Not really just for state inspection it's easy to throw some rollers under it for that.
However you do have to have mud flaps covering the tire if you run a flatbed tray.
I am just running a cherry bomb on it. It realy kinda too loud I may goto a more silent muffler later down the road.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
jon.r
Jul 11, 2015 03:34 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
skoti89
Jul 8, 2015 12:05 AM
