fix or replace rear axel?
I have a 94 22re pickup 4wd,
I took it to a local mechanics personal shop about a month ago needing a couple of things checked out. The biggest was i had zero dope in the rear end and wanted all seals replaced. Well i called them today and they finally admitted that they have yet to work on anything (month long and havent touched it!
) But they told my the rear end needed all seals and bearings replaced. Told me they can either order all the parts and replace them or they can swap out the axel with one the one of the mechanics has on a parts truck (told me the axle is the same including gear ratios)
Long story short, my question is which option would be better/ cheaper?
Any advise would be much appreciated.
P.S. sorry for grammatical errors
Edit: IDK where this needed to be posted?
) But they told my the rear end needed all seals and bearings replaced. Told me they can either order all the parts and replace them or they can swap out the axel with one the one of the mechanics has on a parts truck (told me the axle is the same including gear ratios) Long story short, my question is which option would be better/ cheaper?
Yes it was a little cheaper but i ended up not really having a choice, i had broken teeth in the gears from a loose pinion (what they told me). With a replaced chunck, new seals, new bearings, fluids, and labor the rear end ran me $650. Is this high, low, or average price for the work done? They have put the rear end back together now just waiting on news of the front end.
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
infinityisfive
Jun 16, 2015 06:51 PM
