El Dorado caliper retrofit on rear disc conversion
Old Dec 9, 2021 | 08:00 PM
BigBluePile's Avatar
Well, may be back to the drawing board with these brakes. I may need to bleed them again or just drive on them. Not sure if I got the pads bedded well enough. Seems a little soft on initial push but not like shockingly so. Also, the ebrakes don't hold worth a poop....sigh..
Old Dec 22, 2021 | 09:27 PM
I was finally able to get out and drive and all the brakes work fine. I did adjust the proportion valve to push more pressure to the back. Brakes still seem softer than I'd like so I'm going to try and bleed them again.
Also, I started messing with the linkages again for the ebrake and I think it's going to work. The key is to mash down on the brake and then pull the ebrake. Guess we'll see.
Old Jun 12, 2022 | 04:58 PM
Bled the rear calipers again. Looks like gravity bleeding while whacking with a mallet helped foooo shoooow!
Old Jun 13, 2022 | 11:36 AM
2ToyGuy's Avatar
Don't forget to bleed the LSPV last. Just as important as bleeding the calipers. They can collect a lot of yuck in them. Air too, of course, and if you just leave the old, moisture saturated fluid in it, it won't work properly.
Good luck!
Pat☺
Old Jun 13, 2022 | 01:51 PM
  #25
Good luck!
Pat☺
My old lsvp has been bypassed for many, many moons!
clok
May 5, 2015 07:11 AM
yotaholik
Jan 25, 2015 09:50 AM
RBX
Oct 9, 2011 04:40 PM
thralldad
21
Feb 9, 2009 09:34 AM
AW1090
Sep 30, 2005 06:57 PM
