Divorced T-case
Old Aug 30, 2015 | 11:30 AM
Rowdydudeman's Avatar
Divorced T-case
Is there a fab company that can make a T-case plate and flange the input shaft? My swap is coming to fruition and if I can just divorce the t-case, all my problems will be solved expect building motor mounts! 😁
Old Aug 31, 2015 | 10:05 AM
highonpottery's Avatar
what are you doing that warrants a divorced case?
i know it's been done, usually by Suzuki wheelers since Toyota parts are a common upgrade and the stock Samurai layout is divorced. you can easily google divorced toyota transfercase and get lots of results
Old Sep 6, 2015 | 01:14 AM
wyoming9's Avatar
Red face
Any thing can be built if you want to spend the$$$$
A drawing of just what you want is a big help
The F250`s of the seventies had the transmission and transfer case separate with a drive shaft between them.
What you want should be pretty easy to design and build.
I also need to ask Just Why ????
Old Nov 26, 2015 | 05:54 AM
BottomFeeder777's Avatar
I've seen this done on an older K5 blazer, for equal length drive shafts and to reduce the angle on the front shaft. different truck and case I know but same concept.
Old Nov 26, 2015 | 02:17 PM
wyoming9's Avatar
Red face
Then the never came back I am curious if it was ever done.
jasonty
41
Dec 23, 2018 01:00 PM
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
priest16
15
Aug 6, 2015 07:43 AM
