Cost of SASing an 02 Runner
Old Jun 22, 2004 | 02:29 PM
  #161
sschaefer3's Avatar
Originally Posted by Flygtenstein
If you want to talk about the rig for conditions, then the swapped 3rd Gen is wrong for all of them.
Get an old rig from the big 3. It has power and fenders to hack for clearance. Either that or a Jeep.
Some of this is not beating a dead horse. This is specific to one man's inquiry about his truck.
SteveO, thanks man. The funny thing is I get a kick out of you too.
Pay someone else to hang a solid axle. Leaves should suffice for stiff, throttle down non-crawling. Then leave it open so the wheel spin in your front end will nuke the stock 44 u-joints.
In all honesty buy a 2004 Jeep TJ RUBICON, Front Dana 44, Rear Dana 44, Dual factory lockers and a 4 to 1 transfer case.
I'm sorry but this IS the best solution. Money wise.
I'm off to look at Europes finest lungs.
Old Jun 22, 2004 | 02:33 PM
  #162
shazaam's Avatar
how about a kia sorrento
Old Jun 22, 2004 | 02:41 PM
  #163
sschaefer3's Avatar
No, a Jeep Rubicon, so you can be "cool" on the internet. You know.......................
Old Jun 22, 2004 | 02:44 PM
  #164
SteveO's Avatar
I'm thinking a Super D44....
D44 axle housing
NEW D60 ARB center section
D 60 size axles
CTM u-joints
King Coil overs, stretching up through the fender well, into the engine compartment
modified ford locating links with rod-ends at the frame mounts
pretty psycho huh....
Old Jun 22, 2004 | 06:19 PM
  #165
data's Avatar
Senior Member
I'm sorry, but I'd have to agree with this one guys. I've seen a Rubicon with 33x12.50 boggers and a 2" spacer lift walk up some scary level 5's.
Old Jun 22, 2004 | 07:24 PM
  #166
justinh's Avatar
Originally Posted by SteveO
Ya know, I was just thinking of something.....
What about putting an early Ford Bronco D44 up front with coil-overs? A great cushy ride, and mad flex. I know its still a SA, but the ride would be pretty nice......
this swap is popular among the nissan crowd! there are a few nissan's running around with these set-ups
Old Jun 23, 2004 | 06:20 PM
  #167
Flygtenstein's Avatar
Wristed radius arms and coilovers make a lot of sense. It depends on which side or if both are wristed, arm length and arm angle as to if it is streetable.
Going with a Front Range housing built to the gills would still be cheaper than building that 44 you mention Steve. Dynatrac is another option.
Is this going to happen is 6 months or so? I usually have a 6 month personal window after starting threads like this to get it done.
Old Jun 23, 2004 | 06:32 PM
  #168
SteveO's Avatar
I have a D44 Early Bronco houseing in my garage. The guy I bought it from was planning on getting mad flex out of it. So, he took one of the radius arm attachments (at the houseing) and attached it to a sleeve that would spin on the axle tube. So, one radius arm when attached to the tube, is in reality attached to a sleeve that is wrapped around the axle houseing tube. This way, the radius arms and axle are not acting like a sway-bar, limiting the travel. With this kind of axle tube, coil-overs and straps would be the way to go. Indeed, it would be pretty expensive, but over time, I may be able to talk the boss into the build-up. I don't know about sassing it within a year, but, if I'm already breaking axles(yes, I have broken two), and I want to do more, I think a SA is in the future of the beast....
Old Jun 23, 2004 | 06:34 PM
  #169
shazaam's Avatar
yeah this is going to be this winters project ..sept is not looking to be realistic .. especially if I want to do this on a budget.
got an e-mail back from front range off road sayingthey don't do install, and recommended off road solutions for the install. I'm going to go with someone local, so that if they are bugs I can have them worked out here .. instead of having to deal with them later with someone else. He still didn't give me a cost on the parts ... so I'll e-mail him again.
Old Jun 23, 2004 | 06:38 PM
  #170
Cebby's Avatar
Radius arms with coilovers is the direction my planning is leading me. I just want to be different - never seen this on a 2G - except in Holland...
BTW, I plan to wheel the piss out of the dual locked IFS in the mean time. Timeframe for swap - 18-24 months. (Hope I don't have to swap an engine within that timeframe too )
Old Jun 23, 2004 | 07:33 PM
  #171
Albuquerque Jim's Avatar
Dibs on the 7.5" ARB...I'll even help you swap the beast (I know it will happen) someday.
Old Jun 23, 2004 | 07:43 PM
  #172
SteveO's Avatar
Its and RD90 unit, pretty beefy. I was kinda surprised it survived the shockload when I broke the ORS shaft in CO. I was really worried that I may have messed up something in the ARB unit. BUT, its running great, no leaking, and lovin it.
Old Jun 23, 2004 | 07:47 PM
  #173
I figure by the time you are ready to do a SAS I will be wanting 4.88's so I can go to 35's. So it all works out. I'm serious, so you can consider the cost of the ARB w/ 4.88's into your SAS budget equation.
Old Jun 23, 2004 | 07:58 PM
  #174
SteveO's Avatar
Maybe you can help me by buying all the stuff I have for sale, that will get me started.....
http://www.hunt4steve.com/or/forsale/forsale.htm
MAN, there is a lot of crap on that page!
Old Jun 24, 2004 | 03:20 AM
  #175
AznSky's Avatar
shahzad you should get it done by my guy. He'll save you a lot of money, and he definitely knows his stuff.
Brian at www.jcroffroad.com
Old Jun 24, 2004 | 07:11 AM
  #176
loosehead's Avatar
Get in line, Jim
Old Jun 24, 2004 | 02:18 PM
  #177
Originally Posted by loosehead
Get in line, Jim
Old Jun 27, 2004 | 04:50 PM
  #178
shazaam's Avatar
Quick question .. with the long travel kits .. would I be able to run 37" tires?
Old Jun 27, 2004 | 04:54 PM
  #179
AznSky's Avatar
i know a guy sellin 37 swampers in my club for real cheap
http://www.4given4x4.com/forums/viewtopic.php?t=1214
Old Jun 27, 2004 | 05:18 PM
  #180
BruceTS's Avatar
If you rephrase the question, you'll find your answer.....
Can the stock 7.5" diff and CV axles handle 37" tires? the answer is yes if you have an endless supply of spare parts. The IFS suspension, just barely handles 35's, considering the front SA toyota's break axles left and right on 37's, your only option is going beefier. If your intent on running 37's, then expect to build up a pair of D60 axles and a lot of cutting into your body.
