Bumpers, sliders, armor
Old Feb 25, 2010 | 09:14 AM
Etype R's Avatar
I have all of this stuff in my build thread, but figure a lot of members don't venture into the 84-85 section. So going to start a thread in here of the stuff I have fabbed for my 4runner in here
First thing I had to do after getting my 4runner was replacing the ugly rear bumper
So I tossed something together in Solidworks and bought the steel to get started.
Cut the main tube and mocked it up with jack stands to see how it was going to look. I was able to print out the cut lines using solidworks, this made cutting the angles much easier.
Welded caps on the main tube, this was done with my 110 welder.
I had my brackets cnc plasma cut locally, then welded them together.
Apparently I can't measure very well... Totally fubared the math on the mounting location holes and had to move them.
Welded tubes into the shackle mounts, and added the side bars.
Added some gussets in the corners, probably overkill. But they should help spread the load when I add my spare tire carrier.
And they help fill in the gap in the corners
Finished shot
Other then the 2 filler plates, all of the welding was done with a 220 welder. I also added side supports from the frame to the side bars, but never took a picture of those. Its taken several hard hits on the trail and hasn't moved at all.
Old Feb 25, 2010 | 09:20 AM
Etype R's Avatar
Next up was sliders, decided to build them a week before hitting the trail
So once again I fired up solidworks and made some plans.
Didn't take to many fab pictures, so here they are half way done. One was tacked, other fully welded at this point.
And on the truck, mounted and painted
Old Feb 25, 2010 | 09:23 AM
Etype R's Avatar
Also picked up a set of dented up doors for free, so the day before I was leaving to go wheeling I whipped up a set of half doors too
Lay out some tape
chop chop! Don't hold back
Then cut and bend some fresh sheet metal and weld'er in place
Then get out and wheel
Old Feb 25, 2010 | 09:26 AM
Etype R's Avatar
Next up is the front bumper, starting with the solidworks drawing again. Not sure when I will start cutting and bending tube, I'll post up once I start on it
Old Feb 25, 2010 | 09:37 AM
92 TOY's Avatar
very nice work
Old Feb 25, 2010 | 09:38 AM
4rnrlvr's Avatar
Very Nice Work!!! I'm impressed. Looking great and I can't wait to see how the front bumper turns out. I also love the color of your 4Runner. It's the first I've seen like that.
Old Feb 25, 2010 | 09:39 AM
4rnrlvr's Avatar
Originally Posted by 92 TOY
very nice work
No fair we posted the same thing at the same time. Now I look like a copy-cat...
Old Feb 25, 2010 | 09:55 AM
yoder519's Avatar
nice runner! im pretty excited to how that front bumper turns out. any plans with teh rust? my fenders on my 85 p/u are rusted just like you front ones. im gonna hackem up after the snow melts. im gonna follow the body line of teh stock flare? i guess youd call it.
Old Feb 25, 2010 | 06:47 PM
peow130's Avatar
you should get em cut, then have a shop bend the cut in so its not a sharp edge, plus it looks clean.
Old Feb 25, 2010 | 07:21 PM
Etype R's Avatar
Thanks
Fenders are trimmed all around now, back fenders were welded back up and all the rust holes filled. Fronts are cut, but not finished. I picked up certifit fenders for the front, but waiting to put them on till I know how I want to cut them and can paint them to match.
On my pickup, I rolled the edges of my fenders after cutting them using a pair of pliers, its not hard to do with basic tools.
Old Feb 25, 2010 | 09:40 PM
Mountain Cop's Avatar
I love the rear bumper. Looks sharp, man. I bet a similar look would fit nicely in front.
Old Mar 5, 2010 | 10:35 AM
Stuwy123's Avatar
I can't wait to see that front bumper.
Old Mar 8, 2010 | 09:19 AM
Zachwrenchsr's Avatar
Looks good which solidworks program are you using there is alot of different ones on eBay I am also shopping for a tube bender and tuber notcher any sugestions would help me out alot thanks
Old Mar 9, 2010 | 07:02 PM
4Yoter's Avatar
I think u should add some square tube to the front bumper or add a round tube to protect the rear quarters on the rear bumper. Just to tie all the shapes together. but thats just my 2 cents. They look real good though.
Old Mar 10, 2010 | 05:37 AM
Etype R's Avatar
Thanks guys
Using the standard edition of solidworks, 2010 64 bit. If you have to buy software and want to do round tubing though, I would look at bend tech. Solidworks and tubing don't really go together. I have to call a lot of reference points just to create tubing along different planes.
I might add some plate to the bumper once its finished. And I have considered adding some rear tubing for corner protection in the back, but need to add the spare tire carrier first.
I finally got my stinger yesterday, might start on the front bumper this weekend. I might update the file before I start, or I'll just use the drawing as reference.
Old Mar 11, 2010 | 02:48 PM
Big_John's Avatar
Nice work on the bumper and sliders.
For your front bumper you may want to look at mounting the side support tubes to the side of the winch mount then have the stinger tubes weld to them (and the winch mount). Look like you may be using a Trail Gear mount, or something very similar and there is only a mounting tab that sticks out to the side of them with zero room for tube.
Dont forget to reinforce the POS crossmember!
Old Mar 11, 2010 | 02:50 PM
TOYOTA 1's Avatar
looks good!
Old Mar 11, 2010 | 02:56 PM
Fink's Avatar
Awesome work man, do you have a thread in the actual Build-Up section yet?
Fink
Old Mar 11, 2010 | 09:11 PM
Etype R's Avatar
I ordered the winch plate and stinger from Frontier 4x4, so my bumper will be similar to the ones he sells.
http://www.pirate4x4.com/forum/showt...834&highlight=
I also ordered a frame brace kit from 4xinnovations, which will be welded to the frame.
As for frame tie in points, once the bumper is complete I will look at my options. I will not be adding a winch right away, that got pushed aside for now. I have some ideas, but waiting till the bumper is on the truck before I do anything.
Originally Posted by TOYOTA 1
looks good!
Thanks
Fink
Been keeping a build thread going in the 84/85 section. I personally never even noticed the build-up section until a month or two ago my self. I should just put a link to my build thread in my sig
Old Mar 14, 2010 | 07:55 AM
Etype R's Avatar
Built my front bumper last night, of course I forgot to bring a camera with. Still need to trim the ends of the bumper and finish up a few of the welds, then paint
Went out and snapped a few pictures this morning, I'll post up some more pictures after its painted and back on the truck.
