Bumper build. Finally!
Old 09-07-2010, 09:09 PM
scuba's Avatar
Front end too open? You can never have too much clearance
Old 09-07-2010, 11:54 PM
peow130's Avatar
Don't forget to beef up your front crossmember.
In a wreck, or in serious winching, it'll destroy it.
It's only like 18ga. steel.
Nice bumper, its pretty beefage.
Old 09-08-2010, 06:24 AM
SigEp4Runner's Avatar
I've already seen how weak the cross member is. Last time I went wheeling my stock skid ripped off and the bolt pulled right out of the cross member causing it to bend at the bolt hole a bit. How should I go about beefing up the cross member? Should I weld a quarter inch plate across the front and bottom of it?
Old 09-09-2010, 02:04 PM
peow130's Avatar
3/6th plate across the front, stitch welded.
And then beefing up the top triangles.
TG sells a kit, with pretty good reviews.
after i wrecked my pickup i replaced the front xmember with a 2.5x2.5x.25 wall steel square tube. its beef.
Old 09-10-2010, 12:51 AM
  #25
91 4Runner's Avatar
That's what I did with mine as well...
Good looking bumper keep it up!
Old 09-10-2010, 06:27 AM
  #26
Bandit Runner's Avatar
Bumper looks great! The cardboard mockups are a great idea before actually cutting steel. I always use them too, and have found many problems that I was able to fix before wasting steel.
Old 09-10-2010, 06:35 AM
  #27
Thanks for all the input guys. I'm moving this weekend so I wont get too much done with the bumper but I'll keep posting my progress.
Bandit, the cardboard mock up was all your idea. I loved your bumper build and your skid is amazing so far. I went through your bumper build at least 20 times to gain confidence to drop the money on mine, thanks for the inspiration.
Old 09-10-2010, 07:52 AM
  #28
Rerunn's Avatar
Bumper looks good! Very clean and suttle but manly at the same time lol
Old 09-10-2010, 10:57 AM
  #29
You're welcome. Glad I could help. Keep up the good work.
Old 09-10-2010, 11:06 AM
  #30
camo31_10.50's Avatar
is there any reinforcement behind the plate? or is it just the plate welded together?
Old 09-10-2010, 04:18 PM
  #31
I am going to add reinforcing behind the plate. I am going to add some vertical plates and i'm thinking about adding some 1/4 plating behind it as well. it will be pretty strong when its all finished.
Old 09-10-2010, 06:32 PM
  #32
BigBluePile's Avatar
Nice fab work man!
Old 10-23-2010, 05:13 PM
  #33
So I got some more work done on it. It's all done except for paint.
As for the paint, my original idea was to truck bed liner the entire thing, but my brother asked if he could do some airbrush work on it. So he is going to airbrush the front section and the two sections the turn signals mount in. He is going to lay down a coat of silver and do the art work in black and then finish with a coat of candy red that will match the color of my truck. The rest of the bumper will be truck bed liner. Not sure what color I am going to do the shackles (probably black), but they definitely wont be yellow.
I really just want this thing to be done so I can move on to building a skid plate and brain storming ideas for the rear bumper. If i could do it all over i would try to cut the metal into as few pieces as possible so there was less welding and grinding. Bending the metal would have been a lot less work. I've been looking into winches so i can plan for that as well, they are spendy so that might be put off for a while.
Old 10-23-2010, 06:21 PM
  #34
R.DesJardin's Avatar
Bumpers
Great job, gotta plate bumpers. Keep up the good work and share when you do the updates, right?
Old 11-12-2010, 09:18 PM
  #35
My brother started painting my bumper last week, he has been pretty busy painting a couple other cars. Here is what we have so far. Keep in mind that i gave him free range to do what he wanted with it and it isnt costing me anything. I'm glad its free paint work because I plan on scratching it.
Primer. We used an etching primer so the paint would stick real well.
Base coat. The paint is an orangish color so that when he does the candy red over the top it will match the color of my 4runner.
First layer of stencils
more detail added
One side done
He has finished doing the skulls on both sides and he is going to do something different in the center section. He went and got the truck bed liner and the application gun for it so he can do that as soon as the airbrush and clear coat is done. I told him it needed to be done by Wednesday night this week (Ive been waiting long enough), hopefully he gets it done and I have a pic of the finished bumper by the end of the week.
Old 11-12-2010, 09:23 PM
  #36
Here's a couple pics of the truck he is doing some clear coat repair on. This thing is pretty sweet, it even has train horns hooked up, they are loud!!
The bumpers are insane on this truck
Old 11-14-2010, 04:14 PM
  #37
hyzerponix's Avatar
Dude, those skulls are sick! Folks are gonna think your bumper was made by Affliction, LOL!
Old 12-14-2010, 06:09 PM
  #38
So here's an update:
Its been a very slow process having my brother paint the bumper, he has been busy. He finally got the rest of the airbrush work done and laid down the candy and clear coat. The clear was then touched up and the runs were sanded, cut and buffed. Here it is as it currently sits.
Before touch up
After touch up
Edges taped and almost ready for the truck bed liner.
Hopefully the truck bed liner will be done some night this week.
Old 12-14-2010, 06:16 PM
  #39
Sweet!
Old 12-14-2010, 10:19 PM
  #40
zwhiz's Avatar
Location: where the left turn should have been taken, NM
Sweet!
x2!
Quick Reply: Bumper build. Finally!
