bamachem 3rd Gen Bumper w/ Tire Carrier Build-up Thread
#84
#86
Originally Posted by waskillywabbit
That would make two jobs where he does nothing.
and how many plate bumpers has WABFAB built lately?
BTW, do you have those ARB's working yet?
______________
To everybody else, THANKS!
#88
Grumpy Old Man...
Chastize the 85? Naaah. "Rib" ya a little for not getting one thing done before starting another?
[off topic]Did you order your bender and notcher yet?[/off topic]
#89
wow that thing looks bulletproof, ive been dying to fab up a rear for mine, but our shop is without power, and ive been making welding noises with my mouth, its killing me
#91
don't have a clue actually.
hope to have it done completely before Christmas, but that's going to be pushing it.
gotta get the bumper properly braced up first before adding anything to the carrier.
#95
Thanks.Added a 7/16" bolt at each rear edge of the frame rails (about 1.5" inboard from the trailing edge) and used a load plate inside the frame that is about 1"x3" x1/4" thick to help to support the main rail better until I get it braced.
I then loaded on the rear cargo carrier, two coolers, (6) 7# bags of ice and a fully cleaned and quartered 110# dear and it's doing just fine!
Once the wings are attached to the frame brackets, they will also add more support to the bumper and will stiffen it up even more.
For the wing braces, I'm going to use 3/16" plate and basically have a vertical riser that is welded to the wings on the inside over a large surface area, then contour down and under the body and then back up a touch to the frame. off of this 3/16" plate will be another vertical riser that's welded perpendicular to it that will be one of the body contact points underneath.
Fabbing and pics to come shortly...
#98
lol... the deer is cut up and IN the ice chests, you idgits!
it was more about the WEIGHT and less about looking like the Clampetts.
#99
Well, you are living in the hills now.
#100
Come and listen to a story about a man named bamachem
The guy builds a bumper, now thinks the world revolves around him
Then one day he was driving down the road,
his booty fab bumper broke and he dropped his load.
two coolers...
(6) 7# bags of ice...
a fully cleaned and quartered 110# deer, venison, jerky.
Well the first thing you know ol bamachem's having a fit,
Kinfolk said "That bumper ya built ain't worth a..."
Said "Alabameee is the place you ought to be"
So they loaded up the 4Runner and moved back to Bamee.
Roll Tide, that is. No offense, but no volunqueers.
Well now its time to say good bye to bamachem and all his kin,
And he would like to thank you folks fer kindly droppin in
You're all invited back a gain to this locality
To have a heapin helpin of his bs-pitality.
Hillybilly that is. Set a spell, Take your shoes off so you can count above ten.
Y'all come back now, y'hear?.
Pics
