'86 Xtra-cab Solid Axle Swap
Old Mar 7, 2004 | 05:44 PM
  #161
44Runner's Avatar
Originally Posted by Napoleon047
is that a red rag or grease in the knuckle? if its grease, take it out, you only need to fill the birfield with grease, not the entire knuckle. when you turn, you will be pushing grease out of your knuckle seals.
there is nothing wrong with filling the knuckles although it isn't needed...
Old Mar 7, 2004 | 07:33 PM
  #162
Napoleon047's Avatar
Originally Posted by Shane
And you definitely should fill the knuckle some, otherwise the birf will empty itself in short time and be running dry.
then why does the FSM say just pack the birfield with grease instead of the entire knuckle?
Old Mar 7, 2004 | 07:44 PM
  #163
Shane's Avatar
Don't know, don't care. I'd rather have grease oozing out than a dry CV joint.
Old Mar 7, 2004 | 08:02 PM
  #164
jruz's Avatar
Guest
I think they were just addressing your inferrence that having the knuckle greased was a bad thing. You said...
...if its grease, take it out...
I doubt having it greased is doing any harm.
Jim
Old Mar 10, 2004 | 09:23 PM
  #165
Shane's Avatar
Driveshaft arrived yesterday, just finished bolting it up. I need to trim a little off the front lip of my skidplate as it will hit it at ~6" of droop so I left it off for now. Almost ready to go wheeling!
http://4-low.com/tech/sas/IMG_1649.jpg
Oh ya, Rob. No more calling my truck a "pre-runner", mmmkay?
Old Mar 11, 2004 | 07:30 AM
  #166
WATRD's Avatar
It certainly doesn't qualify anymore
Congrats!
Old Mar 13, 2004 | 05:08 PM
  #167
Shane's Avatar
So, I was like, supposed to be working on my truck today, and stuff....
pfffft! Ya right, on a nice sunny day, fat chance!
Flexing up a bit on a boulder, got a little more travel than that in front but it rolled back when I got out. Rear is being limited by my old now-too-short shocks. Other than that, no rubbing or interference to speak of.
http://4-low.com/tech/sas/IMG_1666.jpg
http://4-low.com/tech/sas/IMG_1667.jpg
Crawling around a mini-boulder field. Had to leave after a few minutes because EVERYONE driving/riding by stopped and started asking questions. I had a small crowd forming...
http://4-low.com/tech/sas/IMG_1672.jpg
I've got a little vibration problem with the front driveshaft over 20mph, but that's my fault for thinking I could get away with not using a double-cardan on the transfercase end. The angles are just wrong for singles. It works fine otherwise, so I'll take my time on getting it changed out.
Old Mar 13, 2004 | 06:57 PM
  #168
KING's Avatar
Looks really nice.
Love the front bumper although you came a hair away from hitting it on the second image.
Is the rig locked?
Old Mar 13, 2004 | 07:14 PM
  #169
Corey's Avatar
Co-Founder/Administrator
Whoooa Shane.
Your rig looks so much different than the last time I saw it.
Flex is lookin' good.
Old Mar 13, 2004 | 08:09 PM
  #170
Shane's Avatar
Optical illusion, the bumper wasn't that close to the rock. I did grind a little off my rear bumper trying to back up that rock tho'...
Is the rig locked?
e-lockers front and rear but they're not wired up yet, so it's open in the rear and spooled in the front. That's the next project after I get the front springs swapped around to the proper sides, I'm getting tired of the lean.
Old Mar 14, 2004 | 07:06 AM
  #171
KING's Avatar
Dual eletric lockers, that's a new one.
Great looking truck, nevertheles.
Old Mar 14, 2004 | 07:09 AM
  #172
Cebby's Avatar
Shane, that looks great. What's the next project with the bender? In-cab cage?
Old Mar 14, 2004 | 07:54 AM
  #173
Shane's Avatar
Yep, most likely.
Old Mar 22, 2004 | 09:07 PM
  #174
upndair's Avatar
Shane, if you wanna come down to my place in Milton, you can give it a ride up our 30 degree ramp and have a good look at how everything's working. I'll have the ramp at our obstacle course in June as well.
Old Mar 24, 2004 | 07:56 AM
  #175
Shane's Avatar
Thanks Gibby, I might take you up on that when I get to finishing up the rear shocks. Besides, it would be interesting to see how it does on a 30° ramp.
Old Mar 24, 2004 | 08:02 AM
  #176
upndair's Avatar
Just lemme know when. The ramp will be going out to my property in Bonney Lake by this weekend sometime. If we go out there to use it, prepare to do a little wheeling at the same time... And make sure that your winch is working!
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
Backcountry411
Jul 24, 2015 08:06 AM
scottyg486
Jul 19, 2015 05:34 PM
