86 4runner buildup
#42
Looks good dude...now you gotta get some SAS on that sucker!
And while you are at it, you'd better check under those chrome fender flare thingies...that is what rusted out my rear fenders....but I would have trimmed them anyway, but you don't want any rust to grow there!
#44
Originally Posted by Jared Ajlouny
there is NO rust on this thing, its a cali truck with 1 owner (plus ) me, it doesnt even have a dent!!!
#46
oh i know, i was just saying since there is no rust there probobly isnt any under those, im going to be taking those things off, the last thing i need is chrome!
Definitely take that trim off, inspect, clean and repair where necessary.
Then do the same thing under the tailgate window trim (pull it up from the outside and check for rust along the top of the gate).
Anyway - truck looks very clean... But Brian is definitely correct about that chrome trim..
#50
finally got some time to work on it today. got all the hangers cut off and now i just need to grind all the leftover. the axle is mounted brakes and steering just need to be hooked up!!!!
#51
You got the diff on the wrong side!
J/K
I hated all that grinding...took forever until we broke out the big 9" grinder...
Take your time and do it right.
I'm up to my armpits in wires tonight, wiring up things to the rear Blue Sea fuse box, including installing a hidden kill switch!
J/K
#52
u scared me for a second....haha
good luck with those wires, im going to be making a secret anti theft thing and im gunna be filled up with wires to!!! its gunna suck, but my truck wont be going anywhere
#55
just finished the rear lift, i love this thing, it is awesome!!!! just need to finish som grinding and put the shocks on and this beast is done FOR NOW!!!!
PICTURES
PICTURES
#57
look again
the E brake rubs against the leaf since i had the axle rotated..i have to figure that out. as of friday i will have a hobart 180 mig welder!!!!
#59
got my welder and have been doing some welding on the shock hoops. the welds arnt the best but they will hold for sure. im still deciding how i want to run the rear shocks, i know i want to do the / \ setup, but on driver side the shock will hit the exaust pipe and i will have to cut it off (need a new muffler anyways) and the passenger side it will hit the e- brake cable..... so many decisions!!!!!!!
that looks like a mighty clean runner you found yourself. Excelent choice on the tires!!!
