4rnnr33's 94 excab build
Old Dec 2, 2010 | 05:38 PM
  #41
4rnnr33's Avatar
Originally Posted by irab88
but i like my a/c in the summer
that's the only thing keeping me from doing so. that and the freon. how did you de-charge yours?
Recharge? With this setup its not charged it uses an in line oiler to lube it then a oil separator after the pump to take it out of the air and I had this setup on my 4runner and just used a 5w30 high grade synthetic oil for lube and its worked great so far.
Old Dec 2, 2010 | 05:47 PM
  #42
irab88's Avatar
no, i mean, you're using the air conditioning pump, right? it's charged with freon (toxic). so to use it for oba (or remove it), you need to get rid of the freon in the system
Old Dec 2, 2010 | 09:13 PM
  #43
4rnnr33's Avatar
Oh I see what youre saying. My truck didnt have ac stock I got the pump and bracket from a friend so it was already uncharged but on my 4runner i took a hose and put a fitting on it that screwed into the schrader valve thats used to recharge the system and stuck the hose in a bottle to drain it. Kinda like an air tool used to pump up a tire but I just used it in the opposite way if that makes any sense? And im also pretty sure that i read somewhere that freon is non toxic unless its burnt. I could be wrong though
Old Dec 2, 2010 | 09:23 PM
  #44
irab88's Avatar
got it
nice write-up. very thorough!
Old Dec 4, 2010 | 08:27 AM
  #45
AnimalMother's Avatar
Awesome job on the on board air...very thorough and professional. any chance we could get a parts list? Sure would 'ppreciate it!
Old Dec 5, 2010 | 10:50 AM
  #46
4rnnr33's Avatar
I bought all of the stuff for this over a year ago so im not 100% sure of part numbers and prices but heres a list:
1) heavy duty metal bowl Coilhose pneumatics inline oiler bought from MSC industrial supply I believe it was around $80
1) heavy duty coilhouse pneumatics inline coalescing filter bought from MSC around $70
1) Intake filter from Kilby Enterprises $28
1)3.5" air manifold from Kilby $40
1)pressure switch from Kilby 120 psi on/ 150 psi off $40
1)Check valve unsure of where I bought it
1) safety release valve off an air compressor I had
1) air tank that was off a dump truck I parted out at work
For the hose I used 1/2" semi truck air brake hose and fittings
1) air pressure gauge from summit $70
I think thats about everything
Old Dec 5, 2010 | 05:03 PM
  #47
shakes_24's Avatar
hey 4rnner33 what brand of tool box is that?
thanks
Old Dec 5, 2010 | 08:08 PM
  #48
4rnnr33's Avatar
thanks
Its a pro tech box
Old Dec 5, 2010 | 08:13 PM
  #49
awesome, thanks for the parts list. excellent bob job.
Old Dec 5, 2010 | 08:17 PM
  #50
4rnnr33's Avatar
No problem and thanks
Old Dec 5, 2010 | 08:21 PM
  #51
hyzerponix's Avatar
Very cool set up! Is there a little skull emblem on the rear bumper?
Old Dec 5, 2010 | 08:32 PM
  #52
travis_h's Avatar
subscribed. that is a sweet looking truck you got.
Old Dec 5, 2010 | 09:39 PM
  #53
4rnnr33's Avatar
yes sir its the ballistic fab skull looks like this
Old Dec 13, 2010 | 04:57 PM
  #54
4rnnr33's Avatar
Havent updated for a little while but heres somthing i found that i thought was cool. For anyone who is thinking about buying the trail gear LED strips if you look on ebay you can get the same exact ones for less than half the price. I paid $19.00 for 2 120cm ones (47.5") and from trail gear it would have cost $47.50 each so thats a huge amount to save on these things. Ill post up some pics tomorrow. I also ordered 2 more smaller strips that shipped out of hong kong and they were only $8 for 2 24" ones so Ill see if they actually show up.
Old Mar 7, 2011 | 02:59 PM
  #55
4rnnr33's Avatar
time to get this thread rolling again. Right now im in the middle of swapping a mercedes om617 turbo diesel into my truck. heres what i have done so far:
Heres the engine
Started off by blocking off the egr and installing the sending unit for a pyro
And built the motor mount plates and cut some tubing for the bushings
Then pulled out the 22re and gutted the wiring harness
Ill be using a 115 amp bosch alternator that bolts right up to the 617
Heres the pilot bearing adapter drilled toyota flywheel and bellhousing adapter plate
Old Mar 7, 2011 | 03:04 PM
  #56
4rnnr33's Avatar
And heres where im currently at the engine sitting in its new home
I had to cut out some of the core support for the radiator. I am using a saab radiator that is skinnier shorter and wider than the toyota radiator
Thats all for now hopefully should have some more updates this weekend
Old Mar 7, 2011 | 06:33 PM
  #57
rattlewagon's Avatar
Thats sick! You need a Mercedes hood emblem!!
Old Mar 7, 2011 | 08:35 PM
  #58
irab88's Avatar
that looks soooooo sweeeet.... i want to do that!
Old Mar 15, 2011 | 12:51 PM
  #59
4rnnr33's Avatar
Didnt get a chance to take much pictures this weekend but i did get it running and have a video of it. My phone didnt record the sound very good but you can kind of hear it. should hopefully be driving it next weekend just mainly have to figure out how to stuff the radiator in it.
Just click on the picture to see the video
Old Mar 20, 2011 | 06:20 AM
  #60
iamsuprman13's Avatar
Looks good man! Nice job on everything, are you gonna be able to convert your on-board air to work with the new engine?
