4rnnr33's 94 excab build
probably about an hour haha maybe less. the most time consuming part is tightening the bolts that go through the bracket into the t case because there is barely enough room to get a 1/4 turn each time other than thats its pretty simple.
I dont like them theyre too tall for me and they ride like hell. But when I had them in my 4runner I liked them because it was alot heavier so they rode alot better and sagged more. I have already pulled the HD spring out of the front pack and am almost thinking about pulling out another one. I would definately go with the 4" springs from what Ive seen they are alot softer when they are broken in.
#26
Well I have gotten a few more things done on the truck.
started getting the on board air set up which uses an ac compressor. I didnt take very many pictures but heres somthing that I havent seen before. If you cut the end of the stock ac hose off at the fitting on the compressor. heres a pic
you can drill out the hole to 7/16 like so
then tap it to 1/4" npt and you then have a custom adapter fitting to go to whatever hose you wanna use
Ill take some more pics of the rest of my setup once I get back up to the shop and I also have my rear bumper done so ill get some pics of that also. Thats all for now Sorrry for the crappy pics
#32
Well I just got done with my on board air setup using the ac compressor and I havent seen a whole lot of pics out there of this setup so here are mine:
Heres the stock fitting on the pressure side that I cut off the aluminum hose the drilled the hole out to 7/16" and tapped to 1/4" NPT
Heres the suction side I just cut the stock ac hose and hose clamped it to a hose barb then theres the inline oiler and filter
Heres the rest of the pressure side. Oil separator and manifold with pressure switch, pressure gauge fitting and safety valve
Heres how I mounted my air pressure gauge and some switches in the cab
And the airtank
And the airtank
#34
love that bumper and the a/c air set-up. is that a cb lug on the bumper (left side)? if it is, does the antenna hit the truck at all?
edit: or is it the air outlet? i looked again...
#35
#38
i see iti want oba now!
