3 Link my 4Runner NO MORE Panhard bar
Old 02-01-2006, 10:55 AM
  #121
Praufet's Avatar
How wide is your rear axle adrian? Also whats the real difference between coilovers like scott and a threaded shock like you have?
Old 02-01-2006, 04:55 PM
  #122
Scottz's Avatar
Yeah I was woundering the same thing.... how wide? I really like that set up but I had my 2.0 12" Bilsteins mounted like that in the rear and the tire rubbed the shock (during articulation). so I was going to swap to a wider rear end like a T-100 or this Currie 9" that's been sitting around here. Both would widen the rear 6+ inches (3" on each side) on the 4Runner but the 2.5 with a coil spring at 4" wide or more (depending on coil wire size) it didn't add up to enough space for the tire not to rub(during articulation). I did come up with a 8" wider rear end but now it's as wide or wider then some full size trucks. And I would have to build 4" long travel arms for the front so it could be the same. Another thing I thought about was notching the frame so the shock could be moved in more allowing more room. I would like to follow this build. Where is it?
Old 02-01-2006, 09:04 PM
  #123
Flygtenstein's Avatar
It is wide. Right now the axle is 64" but I am adding 1 and 1/4" spacers PER SIDE since the axle was specked before the links were. Yes, that is almost as wide as a Tundra.
They are 12" travel 2" diameter SAW's with reservoirs.
The bumpstop compresses about 1.5" and there is a 3/4" safety margin so the axle uses the $50 poly bumps instead of the 500 bucks of coilovers.
It cycles 14" plus or minus.
Schaefer told me not to. These are just really fancy leaf springs.
Old 02-24-2006, 06:45 PM
  #124
deathrunner's Avatar
Looks awesome. I like both of your coil over rears....even if they are just fancy leafs. I think you gain alot by just having a nice heavy duty 2.5" res shock. plus teh adjustability and availability of spring rates is excellent. I look forward to seeing both of your progressions.
Old 02-24-2006, 07:01 PM
  #125
Fancy leaves that are adjustable, rebuildable, revalvable and re-ratable.
Sorry I missed the questions before...
The suspension was built on the bumpstops. On pure vertical compression, the bumpstop bottoms the axle just before the coilover. On articulated compression, as in one up, one down, the coilover bottoms itself on the internal ring before the bumpstops hit. I have around 14" of verical wheel travel right now and will limit that a bit depending on tire clearance.
350 over 650? The is super stiff but you have to fight angles. I am near vertical and have 250/350 IIRC.
Old 02-24-2006, 07:03 PM
  #126
ravencr's Avatar
Looks good Adrian! Have you got it out yet? If not, when are you planning to?
Chris
Old 02-25-2006, 10:16 PM
  #127
Mine is still in progress, not on the trail yet.
Old 05-16-2021, 07:48 PM
  #128
Blake Yota's Avatar
more info
Hey I know this is an old thread, but does anyone know how to contact Scottz? or does anyone have more info on doing a 3 link like this in the rear of a 2nd gen 4runner. or just even more pics for examples. thanks.
shisha1999
03-16-2016 12:25 PM
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 3 Link my 4Runner NO MORE Panhard bar
