1st Gen 4runner bumper/tire carrier
I started building a rear bumper/tire carrier today for the 4runner. The main base is 2x5" .180 wall square tubing. All the legs are .250 wall. I still plan on doing the wrap around ends and stuff too.
![](http://www.toyotaholics.com/support/files/scotty/20070806182330_PICT4854.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070806182409_PICT4856.JPG)
I went with the Rockstomper tire carrier hinge, but decided to try something different with it. I sleeved the bumper with 1.5" .120 wall tubing, welded top, bottom and inside, then slid the lower pin into it and welded it from the bottom only. I have three friends that have broken the hinge section from the vibration that these go through on a normal basis. I don't think its anything wrong with the Rockstomper hinge itself, but the fatigue the upper welded portion goes through when it gets welded to the bumper, so I figured a sleeve would allow it to disperse the load better. Time will tell.
It was getting dark, so I will get better pics of it as I move through for a good write-up.
![](http://www.toyotaholics.com/support/files/scotty/20070806182443_PICT4858.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070806182531_PICT4861.JPG)
Big John came over today and we knocked out almost the whole damn thing. But, we ran out of MIG wire right near the end. This bumper is sick IMO
![](http://www.toyotaholics.com/support/files/scotty/20070807195408_PICT4881.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195436_PICT4882.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195549_PICT4889.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195625_PICT4888.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195702_PICT4897.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195727_PICT4899.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195822_PICT4904.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195848_PICT4903.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195914_PICT4906.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807195945_PICT4911.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807200016_PICT4910.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070807200913_PICT4908.jpg)
My bitchin BTF clamp.........[
![grin](https://www.yotatech.com/forums/images/smilies/grin.gif)
I wish I would have just brought that stock 85' I had instead of selling it the week before we moved. But, oh well.
My 88' financed the move out here, but I will eventually build a crawler out of the one above. I already started gather parts for it.
Nice design and fab. ![Great](https://www.yotatech.com/forums/images/smilies/great.gif)
When I did mine, which pails in comparison, I was surprised how much the body moves on the rubber bushings at the body mounts. I can get a good 3/4" of shift on harder rock bumps. Something I didn't realize until I was all done.
Just wondering if you are going to have an issue with the carrier so close? Probably just rub a little on occasion if anything. Looks like you are pretty much done, so I am not sure why I am throwing this out there.
Guess maybe something to consider and if possible increase your riggle room slightly to allow for that body to move a round a bit without hitting anything it shouldn't.
Well, I guess you can always adjust it later if a clearance issue develops.
Really like how your wings turned out. Simple but effective.
Is that a tab at the top of the tire carrier? If so, what's it going to be for?
I have no latch at this point. Its just a clamp I use for welding for now. I am still waiting on the Destaco setup I ordered which should be here in a few days.
The clamp will work fine for now without anymore weight on the carrier.
Hinge s from Rockstomper.com. Buts its just your typical trailer axle spindle setup. Runs around $45.
Looks like this is TOO tight as once you get a vibrating tire on there it is going to break/crack the black plastic on the tail gate that has the key hole for the rear window.
Looks good.
Looks good.
![guitar](https://www.yotatech.com/forums/images/smilies/guitar.gif)
I have pushed very hard against it already and it barely moves at all. I'm 240lbs, so its not like a tire is going to put more pressure on it either.
Still waiting on the latch, but I went ahead and mounted everything up and used a ball pin shaft in the meantime to hold it in place. I get ZERO vibes out of it at this point too.
![](http://www.toyotaholics.com/support/files/scotty/20070809133108_PICT4917.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070809133132_PICT4918.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070809133209_PICT4919.JPG)
![](http://www.toyotaholics.com/support/files/scotty/20070809133238_PICT4920.JPG)
