1st fab project done what do you think
Old Jun 4, 2007 | 08:27 PM
gametom's Avatar
ok so i have done little crap before but this was my first real fab project. A push bar for my 91 4runner and i think i did ok all 3 bars sit level at least heres what i started with
then i built the uprights
at this point i noticed that the passenger side was about 3/4 of a inch lower than the driver side so looking more thourgholy i noticed that there's a heavy peice of angle iron welded on to the frame there. so some spacers and longer bolts and back to fabing.
here i got the first horizontal bar welded in place
one bar left to weld on
and finally it's done i have a push bar welded up and very stout sch80 pipe is a wonderful thing. so now i want to add a brush guard here's my idea
the thick red is the same 2" pipe as the push bar the middle thickness line is 3/4 sch80 pipe and the thin red lines are 1/2 rebar. the orange is the same dimensions just i'm not sure if i should build it or not let me know what you think
Thanks
I need a beer
Old Jun 4, 2007 | 08:30 PM
the_gunslinger's Avatar
does it only mount with the flatbar at the bottom?
good job, i'd go with the light guards...let the bumper fend for itself
WoOt! Ryobi!
Old Jun 4, 2007 | 08:34 PM
gametom's Avatar
WoOt! Ryobi!
ya it only mounts on the bottom the flat bar is 3" wide and 1/2 thick
where else can i mount it?
o and what color should i paint it after at least 2 coats of por 15 ?
Old Jun 4, 2007 | 08:38 PM
why not drill through the bottom of the bumper for another mount?...just curious.
rhino?
i dunno...i do all my stuff in flat black, but thats only cause it's $.88 a can
Old Jun 4, 2007 | 09:00 PM
gametom's Avatar
that should work thanks for the idea
rhino as in rhinolinner is that better than por15 anybody know
Old Jun 4, 2007 | 09:02 PM
no problem, i'm a fabricator by nature...they don't ever seem to make the things i want for what i want to pay...
Old Jun 5, 2007 | 10:08 AM
gametom's Avatar
anybody have any suggestions or comments?
Old Jun 5, 2007 | 11:01 AM
Elvota's Avatar
I'd like to see a gusset of some sort behind the uprights to your flat plate. Something to help the flat plate from bending easily. Might even stiffen it up if you are planning to mount lights to it later on.
If you are really planning on pushing anything with it, it's most likely going to flex back to the bumper. You could prevent this with some thick tabs and bolts through the bumper, using spacers for proper depth.
If you goal is to keep everything away from the bumper, and not drill any holes, perhaps you can attach some thick rubber or urethane bumpers to the back of your push bar to help reduce the flex.
If you add the light guards, you may be able to reinforce the ends by wrapping a bar under the fender back to the frame. You just have so much leverage against that flat plate as it is designed now.
Overall, not a bad job for your first fab project.
Old Jun 5, 2007 | 03:18 PM
locked stock 84's Avatar
take some rebar and go from the top of the pushbar back and down to the top of your bumper. either bolt it down or make some kind of bumper/ foot with rubber or plastic. also, I would make the supports just a little longer as to put some forward tension on the pushbar.
have fun!
matmattmatthew
10
Feb 9, 2021 04:15 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
MaK92-4RnR
Oct 28, 2015 02:45 PM
1965chevy
Sep 20, 2015 07:33 PM
justdifferentials
Sep 5, 2015 06:52 PM
