1985 Waggy 44 - If money were no object, how would you build it?
Old May 29, 2005 | 06:32 AM
  #41
sschaefer3's Avatar
I would have gotten the Front Range Axle but it is set up for spring over and Brian said it would was not setup for spring under. Caster would be off.
I talked to him on the phone a long time about it. I like the spring under I have with the Dana 44, my truck is taller than most lifted 3rd Gens by an inch or two but no where near what a spring over swap would have gave me. I have kids and stuff to load and it is a perfect setup for me.
For practical use in real life, I had to stay low. I really like it.
Old May 30, 2005 | 12:39 AM
  #42
AxleIke's Avatar
Originally Posted by sschaefer3
Why did I go so strong. I hate fixing things on the trail. Plain and simple, I don't ever want to break.
This is the attitude that i have. Trail fixes are the most annoying, most frustrating, and most time consuming of all things in this sport.
If money was no object, than overkill wouldn't be enough, i'd go for UNkillable, assuming that was possible.
On a side note, if you don't want to break axles, you could always go to 28 inch tires run by a 22re, and you won't have enough torque to break them.
Old May 30, 2005 | 05:22 AM
  #43
waskillywabbit's Avatar
Toy SF axles are lighter, better ground clearance and just as strong as anything out there, if not stronger, if you upgrade the axles and r/r the old/worn out stuff.
Old May 30, 2005 | 05:54 AM
  #44
sschaefer3's Avatar
Wow I never knew a short little passenger side drop Toyota Mini axle would fit a 3rd Gen?
Who would have ever known?
Old May 30, 2005 | 06:06 AM
  #45
I didn't say it would you old
Old May 30, 2005 | 06:10 AM
  #46
sschaefer3's Avatar
Ok, I see you were posting that for reference to the Front Range Houseing.
Old May 31, 2005 | 03:59 AM
  #47
ravencr's Avatar
Thanks for the info guys!
Chris
Old Jun 2, 2005 | 09:12 AM
  #48
Chris Joe Darling is running stock w/ 5.38 gears and an ARB w/ 35's. He's broke one shaft but it was the original 25 yr old 297 joint. I'm running 297s w/ 38 TSL's and haven't broken yet in almost a year. If money were no issue though I'd just sell you my 87 waggy 44 w/ 4.88s and chevy flattops and build my D60 Only thing though w/ a dana toy combo is the closest match is 5.13 dana 5.29 toy. Since I want wider and bigger and the gears won't match like I want it means I have to now build my rear 60 as well
Old Jun 2, 2005 | 09:13 AM
  #49
ravencr's Avatar
And he broke an outer joint with me up in Caryville, TN.
Chris
Old Jun 2, 2005 | 12:10 PM
  #50
Thats the one I'm talking about. The 25/30 yr old 297 or whatever came stock in his waggy axle. Not only did it mangle the shaft it tool out his driver side knuckle also. Not bad considering he only replaced what was needed to get his truck going as he was hurrying to get it done for an event
Old Jun 2, 2005 | 12:23 PM
  #51
ravencr's Avatar
Yeah, I was there, and it looked pretty! If you have 5.29's I might considering buying your axle instead, but I think I'm going to get the one I've found already.
Chris
Old Jun 5, 2005 | 12:27 PM
  #52
Hyperlite's Avatar
The Ultimate D44 would be HP to start with, ARB has a 40 spline locker and you add D60 Knuckles, 40 spline d60 inners and outers, warn fusable hubs and you have clearence, low weight and strength.
I have a set of full size axles from a 78 ford, D44 hp and 9" rear with limited slip that are going under my '69 bronco sitting in the yard. I plan on running 40"+ swampers so I am gonna use an Ox locker with moser or warn shafts and CTM joints.
If you are worried about breakage then bring spare shafts, joints, hubs and a yoke.
Old Jun 5, 2005 | 04:27 PM
  #53
ravencr's Avatar
Why not just buy a Dana 60 if you're going to do all that?
Chris
Old Jun 5, 2005 | 09:25 PM
  #54
Nitro Hotpants's Avatar
Chris
D60's are massive. have you ever seen how big the pumpkin is? you would need at least 37's to keep from dragging all over the place. plus most (if not all) D60's are full width and would need to be cut down to size.
Old Jun 6, 2005 | 04:41 AM
  #55
ravencr's Avatar
But, if I decided to rebuild the axle only, adding only gears and a ARB locker, what parts would I need to replace to make it like new?
Chris
Old Jun 6, 2005 | 04:46 AM
  #56
bamachem's Avatar
Chris
steve's parts list if you want it to be a "new" waggy dana 44
Old Jun 6, 2005 | 05:22 AM
  #57
ravencr's Avatar
Minus what upgraded components, I meant to ask?
Chris
Old Jun 6, 2005 | 05:26 AM
  #58
bamachem's Avatar
lol....
well, i've seen you drive. you'd better stick w/ indestructable...
Old Jun 6, 2005 | 05:30 AM
  #59
sschaefer3's Avatar
Chris
Superior axles and CTM.
Old Jun 6, 2005 | 07:07 AM
  #60
ravencr's Avatar
Thanks guys! Steve, do you have a list of places you bought this stuff from?
Chris
