14 Bolt FF into a 1988 pickup
Old Apr 20, 2005 | 02:49 PM
TinyTruck's Avatar
Question 14 Bolt FF into a 1988 pickup
What is involved in putting a FF 14-Bolt under a 1988 toyota pickup.
Why:Because I can
Old Apr 20, 2005 | 03:07 PM
kyle_22r's Avatar
redoing spring perches, brake line routing, and modding your driveshaft(either by getting a flange to replace the yoke on the 14b, or having your driveline remade with a yoke for the 14 bolt)
that said, a D60 or 9" is a better swap for a toyota if you need a bigger ring gear
Old Apr 20, 2005 | 03:23 PM
TinyTruck's Avatar
what would be stringer on the D shaft doing the flange swap or redoing the shaft to accept a yoke
Old Apr 20, 2005 | 05:24 PM
kyle_22r's Avatar
would be much slicker to use a flange on the yoke -- high angle driveline would probably be able to set you up with one. they're known for their fondness of toyota u-joints and have all kinds of flange conversions for american axles
Old Apr 20, 2005 | 05:25 PM
crash's Avatar
Those diffs may be strong, but they are plain too big unless you wanna run at least a 44" tires to get any clearance at all...
Old Apr 20, 2005 | 06:18 PM
TinyTruck's Avatar
yeah I know that the ground clearence will blow goats but I have plans for 40in tsls, that and people are either shearin ring and pinions or shattering spider gears (I dont wanna do either)
Old Apr 20, 2005 | 06:56 PM
runnerboy97's Avatar
what are you gonna run for a front axle?
Old Apr 20, 2005 | 07:32 PM
crash's Avatar
I don't have that problem with my rear end, and its got more clearance than my POS d44
Old Apr 21, 2005 | 04:10 PM
TinyTruck's Avatar
Leave it for the time being, and hopefully I can find a cheap ifs lift
Old Apr 21, 2005 | 07:12 PM
you do realize how much wider the rear is gonna be compared to the front, right.
Old Apr 22, 2005 | 12:15 PM
TinyTruck's Avatar
of course I realise that, I may be 15 but I am certainly not that dumb A d60 or d44 will come when I get the $
Old Apr 22, 2005 | 05:12 PM
crash's Avatar
A 60, well, you better save LOTS of lunch $$..
I am going to start my new front here soon..... upgrade time
Old Apr 23, 2005 | 06:59 AM
Mikeyg79's Avatar
Got a buddy with 40's, ran a stock 8" rear (think with cromos) and a D60 front.
Throttle happy guy with way low crawler gears.
You should re-evaluate your build
Old Apr 23, 2005 | 07:24 AM
DudeBud's Avatar
and the 8" is holding up?
Old Apr 23, 2005 | 07:36 AM
crash's Avatar
Mine didn't. Broke 2 arb's and one ring/pinion. Needless to say, rear is pretty much bullet proof.
Old Apr 25, 2005 | 11:49 AM
kyle_22r's Avatar
toy axles are pretty good units, unless you're crash. then they're a POS
keep in mind that a toy rear has 30 spline 1.3" shafts, get a V6 carrier and odds are unless you're crash, it'll be fine with up to 38s. front end shafts are now near bulletproof with bobby long's 30 spline birfields, i wouldn't hesitate to run 38s with them. of course, i've got a 4 banger, not a 4.3 with an SM465 and dual cases
14 bolts are best used for planting crops...
Old Apr 25, 2005 | 04:17 PM
Mikeyg79's Avatar
someone else drove it and sheared the pinion shaft
Old Apr 26, 2005 | 04:46 AM
Mikeyg79's Avatar
"QUOTE FROM A POST BY BOBBY LONG"
"We did some testing on some stock stuff all the way up the Dana 60 here's some numbers they broke at;"
Stock Birfield= 3,700 ft lbs
Birf Eliminator kit= 4,020 ft lbs
Stock inner shaft= 4,360 ft lbs
Longfield stock treated birf= 4,800 ft lbs
Superior 27 spline 4340 chromo inner axle= 5,200 ft lbs
Longfield 27 spline 4340 chromo inner axle= 6,820 ft lbs
Longfield 30 spline 4340 chromo inner axle= 8,200 ft lbs
Longfield 4340 birfield stub failure= 8,200 ft lbs
Stock Dana 60 35 spline= 8,300 ft lbs
**UPDATED FIGURES**
Stock Toyota Birfield, 27 spline ................ 3,700 ft-lbs
Toyota Birf Eliminator kit ...................... 4,020 ft-lbs
Stock Toyota inner axle, 27 spline .............. 4,360 ft-lbs
Pigs 4340 Toyota inner axle, 27 spline .......... 4,700 ft-lbs
Longfield stock treated Toyota birf, 27 spline .. 4,800 ft-lbs
Superior 4340 Toyota inner axle, 27 spline ...... 5,200 ft-lbs
Longfield 4340 Toyota inner axle, 27 spline ..... 6,820 ft-lbs
Yukon 4340 Dana 44 inner axle, 30 spline ........ 7,900 ft-lbs
Longfield 4340 Toyota inner axle, 30 spline ..... 8,200 ft-lbs
Longfield 4340 birfield stub failure ............ 8,200 ft-lbs
Stock Dana 60 inner axle, 35 spline (used) ...... 8,300 ft-lbs
Stock Dana 60 inner axle, 35 spline (new) ....... 8,320 ft-lbs
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
raiderhawks00
Jul 8, 2015 06:23 PM
