Trucks, 3rd gen-'89 to '95 Post your trucks here
Oil pressure sender help, 89 pickup.
Old Jun 4, 2012 | 06:05 PM
beensoko's Avatar
Hey guys, I have a 91 4x4 pickup with a manual transmission. I recently swapped a better condition 89 22re and pulled the existing 22re.
The engine purrs but I cant get the oil pressure sender working!! The new engine came with a oil pressure switch, I removed it and installed the old oil pressure sensor/sender; resulting in the needle not moving in off/low position.
I rewired from the quick connect and purchased a new oil pressure sensor for a 91 pickup (my error, should have been a 89). Anyways same error, needle stays parked in off position.
When i ground the wire to the base of the sensor the needle jumps to full pressure indicating the wiring is good.
Using a multimeter and checking the resistance between the sensor connection and battery negative terminal shows open circuits on both sensor.
This is driving me crazy, any ideas?????
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
