Trucks, 3rd gen-'89 to '95 Post your trucks here
91 Truck Oil Change and Turn Signal Question
Old Sep 4, 2008 | 10:32 AM
bge187's Avatar
FYI: I have never done any auto repair in my life
1) I would like to change my own oil and replace my oil filter on my 91 pickup. IS this something someone with little to no knowledge could handle?
2) My left turn signals do not appear to be working and the arrow is clicking faster than normal. I tried checking the fuse by checking the turn signal fuse on the panel to the lower left of the steering wheel and that did not seem to fix the problem. Is it possible that a bulb could cause both signals to stop working? Did i check the wrong fuse? I did not check the fuses located under the hood and behind the panel beneath the glove box.
Any tips and or suggestions any of you can provide would be most appreciated.
Also, one more question. When I bought the truck I received a recall for the steering column that had not been replaced yet. Is the bunk steering column an immediate threat to my driving safety? Is it safe to do light off-roading (rough trails) without replacing the steering column?
Yont283
Sep 23, 2022 08:06 PM
toy89yota
Jun 24, 2015 01:18 PM
infinityisfive
Jun 16, 2015 06:51 PM
Mohamed
12
Jun 9, 2002 08:16 PM
