4Runners-3rd gen Post your 3rd gens here
My 4RNR
Old Apr 2, 2006 | 12:03 PM
PO2SIMS's Avatar
My 4RNR
Please Don't Post Here
After buying
I first wanted to let the engine breath
Then I din't like the stock (shot) Shox
I then replaced this
With this
I then had a catback exhasut made w/ a Dynomax muffler. Letting the little 3RZ breath makes a huge difference. Before I could barley get the engine to rev to redline. Now it's very peppy and free reving. Before w/ 31" tire it would take forever to accelerate going onto the freeway. Now it can scream up the on ramp.
Old Apr 2, 2006 | 12:34 PM
PO2SIMS's Avatar
I wanted more stopping power so I got LCE cross drilled rotors and EBC SUV pads. The pic was taken for something else, but u can see part of the rotor.
I then installed a LCE short throw shifter. It is only 1/4" shorter, but has a much shorter throw. While I was at it I installed Redline MT90 into the tranny.
After a while I wanted more clearance, so I installed a Daystar 2.5" lift with BFG AT 33x10.50x15
I had to make a few parts to complete the lift.
I first just bolted the Panhard bracket on, then decided to weld it on, with an upper brace.
I cut the swaybar endlinks in half, then slipped a pipe over them and welded back together making the endlink the proper length for the lift.
I plan on makingbump stop brackets to limit down travel in the front, here is a sketch
Old Apr 3, 2006 | 01:30 PM
PO2SIMS's Avatar
The rear end never felt like it was braking properly, and I knew it had something to do with the LSPV. So while rotating the tires I made sure the rear brake shoes were properly adjusted, which they were. So I deceded to lock out the LSPV so that the rears get full pressure. I then test drove it on dry pavement. When I slam on the brakes the rear locks up, but it still drives straight. I even slammed on the brakes starting into a turn and it still felt stable. The big thing is that under normal to hard braking I no longer get front shake and it slows down very evenly.
Old Apr 18, 2006 | 01:26 PM
PO2SIMS's Avatar
I flipped my hitch a few months ago. Now I have 3" more of clearance.
tns1
10
Oct 30, 2010 06:57 AM
rangerruck
Feb 5, 2009 07:49 AM
Bobthebuilder
Aug 21, 2008 04:55 AM
thook
Jul 16, 2007 09:18 PM
