4Runners-1st gen Post your 1st gens here
jvc971's 89 runner
Old Aug 20, 2008 | 06:10 PM
jvc971's Avatar
jvc971's 89 runner
i just bought a 89 4runner 8/16/08.
it has around 240,000 miles
36-15.5-15 mickey thompson baja claws on m/t rims.
it is 3.0 v6 automatic (burnt tranny-have to shift from low up to drive)
no carpet
no rear seat
torn driver seat
4"suspension lift
3" body lift
rear chevy springs stuffed and shackles are resting on frame.
4"block on top of chevy springs
bushwacker fender flares
front and rear locked not sure if welded or what yet.
unknown gears
smittybuilt front, rear bumpers and side steps.
no fan shroud
no air filter
Old Aug 28, 2008 | 06:46 PM
jvc971's Avatar
so since i have gotten my 4runner i have;
installed 4" rear springs
i have fixed the rear shackles and now it rides alot better.
i am doing a manual tranny swap at the moment so i will take more pics and post them up.
Old Sep 2, 2008 | 10:07 AM
jvc971's Avatar
so im still in the middle os doing the manual conversion. i had to go to 6 different hardware stores to find the flywheel bolts but found the clutch bolts the first store.
i got the auto tranny out and replaced the oil pan gasket did a oil change and replaced the rear main seal. still need to find the wiring harness for the reverse lights, to start.
Old Sep 13, 2008 | 02:28 PM
jvc971's Avatar
this is what has been going on;
9/6/08-
i finished the tranny today finally got it all bolted up. i took off the shifter electronic piece from the auto tranny and set it in park and it fired right up. i also put the shifter in and then realized it needed the bushing . the clutch grinds when put in reverse.
9/7/08-
i went to the junkyard in the morningit was 106degrees at 1 in the after noon when i left. they had a 88' 4runner out there with a 350 turbo tranny black with 35's. it had the 4&3 suspension kit with traction bars on the rear. i bought;
1.rear seat
2.tranny drive shaft piece
3.amp pire wire
4.rcas
5.mallory ignition system
6.rear window switch
7.rear tailgate cover
8.driver side fender
9.gas cap cover
when i got home i installed the new amp power wire, rcas and ran that to the back. put the drive shaft piece in and it fit so i bolted up the new lenghtened drive shaft. put new fender on it looks alot better. put on new gas cap cover.
9/8/08-
i bought new-slave cylinder, air filter, spark plug wires. put new cylinder on and i still have problems with the clutch. i mounted my amp and box in the rear behind the rear seat. i am running a 12" mtx jackhammer, and a 12" mtx thunder in a 2 12" sealed box with a 400watt alpine amp mounted on the side. i have a pioneer head unit.
9/9/08-
i bought a new master slave cylinder and installed that. it helped a very tiny bit but didnt make the clutch any better.
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
