Arizona Arizona Chapter
BLKNBLU's SAC
Old May 25, 2009 | 07:35 AM
  #181
toyospearo's Avatar
Looks great!!!
Balanced out perfectly.
Nice work man!!
Get some action shots
Old May 25, 2009 | 01:08 PM
  #182
Red Rover's Avatar
Dude! Looking awesome Mike!
Old May 25, 2009 | 07:26 PM
  #183
BLKNBLU's Avatar
Thanks to my friend Jeff, I can now accomodate you.
Thanks Jeff!
I actually failed on this line due to steepness and loose surface. Hence, my need to move along on a lower T case gear.
Ssstrrrrretch...
Just for fun, me next to a couple stockish 4Runners.
Old May 25, 2009 | 07:36 PM
  #184
toyospearo's Avatar
SO COOL!!!
HOLY FLEX!
That Runner is so sweet. You must be stoked!!
Keep the pics comin!!
Old May 31, 2009 | 08:25 PM
  #185
Djlarroc's Avatar
Originally Posted by BLKNBLU
Ssstrrrrretch...
Old Jun 16, 2009 | 07:08 PM
  #186
Hayes's Avatar
Why do you have a track bar on the rear axle? With leaf springs, isn't that kinda moot?
Old Jun 16, 2009 | 07:51 PM
  #187
BLKNBLU's Avatar
Most of the guys here have experienced pretty significant axle wrap with similar setups. I didn't try it without the trackbar so I can't personally attest to how it would be without, but Schaefer has built or fixed enough of these to know what it needs. I figured it was just as well to set it up right in the first place.
Old Jun 16, 2009 | 08:05 PM
  #188
Hayes's Avatar
interesting. I have never heard of that before.
Old Jun 19, 2009 | 01:29 PM
  #189
AZ4ME's Avatar
Nope, not a moot point. With real flexy/soft leafs in the back, you tend to get axle wrap under load (climbing, hard acceleration, towing, etc.). The wheels will actually hop from the leafs wraping and the axle rotating. If you use lift blocks in the rear with leaf springs, it can amplify the issue also. A lot of times if you by a lift kit that uses rear blocks of a good size, they will include a traction bar.
I had the issue with the torque from the crawler box and steep climbs. You could see a definate improvement after the traction bar was installed.
Google 'axle wrap' and you can find more info than you could ever read.
Old Aug 3, 2009 | 06:03 PM
  #190
BLKNBLU's Avatar
Update
Finally got around to taking care of this...
Went to see Steve for a trim and ended up with this.
So hopefully I'll get to squish the springs again soon and check it out. If only it wasn't a million degrees out...
Old Aug 3, 2009 | 06:09 PM
  #191
sschaefer3's Avatar
I see a box on the back what is in it?
Old Aug 3, 2009 | 06:55 PM
  #192
BLKNBLU's Avatar
That would be some stealth bling.
Steve, for future reference it did not have a gasket included
Old Aug 3, 2009 | 07:00 PM
  #193
sschaefer3's Avatar
That is the tranny seal on the tag.
Old Aug 3, 2009 | 07:24 PM
  #194
lofreqjeff's Avatar
So, when is that going in?
Let me know if you need a hand - I'd like to help!
Old Aug 3, 2009 | 07:55 PM
  #195
wormhole's Avatar
Nice, Mike.
Old Aug 3, 2009 | 07:57 PM
  #196
BLKNBLU's Avatar
I was thinking of something along the lines of #36146 in this pic
http://www.toyodiy.com/parts/p_U_198...MDEA_3609.html
I'll take you up on that. Probably be a couple weeks. The DD needs some attention first so I don't want to dig in just yet.
Old Aug 4, 2009 | 10:48 AM
  #197
sschaefer3's Avatar
Yes 36146 is what you need.
Old Sep 14, 2009 | 09:41 PM
  #198
BLKNBLU's Avatar
Yay! The 4.7 is in without drama. Even though I had a helper (thanks Jeff), we both got so engrossed that no pics were taken. So all I've got is after pics i.e. clean t case and dirty tranny.
Next up is to check it all out on the trail next w/e.
Old Sep 14, 2009 | 10:38 PM
  #199
i_love_tacos's Avatar
niiiiiice. looks awesome!
Old Sep 15, 2009 | 06:51 AM
  #200
wormhole's Avatar
What's next for it??????
