Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Test
Old Oct 22, 2008 | 04:01 PM
mt_goat's Avatar
Test
Getting ready to have a custom exhaust system built from the cross-over back. I couldn't find anyone that sells a Toyota O2 sensor bung to weld into the new exhaust piping. After talking to a friend that works at the local Toyota dealer about where to get one, he says why don't you just make one? I hadn't thought of that Jason, thanks for the idea. So here's how to make your own O2 sensor bung.
I started with a piece of 3/8 steel and marked the outline with a gasket and drilled and tapped some holes (8mm x 1.25):
I used some exhaust studs from the dealer that were left over when I was putting on the ORS cross-over.
Then I started cutting it out with a cutoff wheel on an angle grinder:
After using a grinder and beltsander to smooth it out:
Now that was one bung, but I need two for the 5VZ right. The first one took me about 2-3 hours to make so I decided to try cutting an old one out of my old 3.0 exhaust pipe and using it. That took about 2-3 hours too, counting replacing the old studs and smoothing it out with a grinder and beltsander too.
Here's the two side by side, the one I made from scratch will have to be welded in parallel to the pipe since it's not curved to the shape of the pipe:
moparbay
Mar 10, 2023 03:50 PM
Obmi
Oct 30, 2015 04:27 PM
accuracy
Sep 20, 2015 07:44 PM
Boomer8404
Sep 20, 2015 06:15 PM
Boomer8404
Sep 10, 2015 09:01 AM
