Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Really tough Shifting gears
Old Oct 4, 2019 | 02:11 AM
Joez22re's Avatar
Replaced the slave cylinder a few months ago last night I replaced shifter bushings kit was all deteriorated and changed the clutch gear oil with 3 quarts of 75-95 Valvoline I thought for sure when I started the truck I was going to drive down the road with no problems shifting the clutch master cylinder is not leaking The clutch pedal seems to be pretty good I haven’t checked yet if the pedal bracket is broke as I spent over three hours you tubing possible problems my next step is on my lunch break I’m going to bleed the clutch master cylinder again if anybody has something to say I would really appreciate it
