Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Miss Fire Cylinder #3
Old Jul 18, 2023 | 07:19 AM
Pooch242010's Avatar
Hey Everyone,
I have a 93 4runner 3VZE that I have been having some trouble with Cylinder #3. Below is a list of everything I have done. It also is running rich which I think the engine is compensating for the bad cylinder.
Replaced Cap & Rotor along with plugs and wires.
Tested all injectors and the one on #3 was bad but after being replaced nothing changed. Also went back in and swapped the new injector to another cylinder that I knew was performing correctly.
Compression was checked and that is reading correctly.
When I tested to see if the issue was fixed after the tests I would rev the RPM's and removed the plug wire and it has no effect on the engine.
I also swapped out the Ignitor and that did not fix the issue.
Plan on testing the injector wire with a noid light next.
I am wondering if the ECU could be the issue or the rocker is stuck. Any insight on this would be much appreciated
Pete59
May 14, 2021 07:09 AM
ToyoterDestroyer
Feb 3, 2020 10:23 AM
i3oykin
Jun 13, 2016 07:45 PM
