Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
87 22r
Old Aug 4, 2025 | 06:15 PM
freightliner's Avatar
87 22r
Did smog emissions delete and need to know what vac lines I need for distributor,high cold start
Old May 31, 2026 | 04:06 PM
NoahT265's Avatar
After a smog/emissions delete, a lot of the original vacuum routing diagrams stop making sense, so the key is simplifying everything to what the engine actually needs to run properly.
For a distributor setup, you usually only need one correct vacuum advance source. That should be a ported vacuum line from the throttle body or carb, not full manifold vacuum, unless your setup specifically calls for it. Everything else that used to go to EGR, charcoal canister, or emissions solenoids is typically removed or capped.
For a high cold start idle, most systems originally used a thermo-vacuum valve or idle-up VSV. After deletes, people often just rely on a properly set base idle screw or keep a simple vacuum idle-up line if the hardware is still there.
The important part is making sure you don’t have any vacuum leaks. Every unused port must be capped, otherwise you’ll get https://roobetcom.pro/ rough idle, high cold start issues, or timing problems.
JHH
Nov 10, 2021 10:03 AM
ride4x4forlife
Aug 8, 2007 06:24 PM
