Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Toyota 8" U Bolt Flip Kit from RUFFSTUFF!
Old Jun 17, 2016 | 03:10 PM
Gravel Maker's Avatar
FormerVendor
This kit will replace the stock U-bolt assembly in a spring under, or spring over setup with Round Bend U-bolts giving you not only more ground clearance, but also pointing the threads away from the rocks you drive over which can make them impossible to remove without cutting.
These, like all of our U-bolt kits feature 3/8” thick Top plates, each with three available holes for the center-pin, which when used with our spring perches gives you the ability to move your axle forward or backward an inch very easily.
The U bolts are a 5/8” fine thread, Grade 8 rod that we bend in house, and they all come with not only extra-thick flat washers, but also Grade 8 tall-nuts that have ~ 75% more thread engagement than a standard nut.
One thing to keep in mind is that the stock configuration mounts the shock to the original U bolt plate, which means that you will need to come up with a new way to mount the shocks to the axle.
Old Aug 30, 2016 | 04:54 PM
FormerVendor
First step for any Toyota build!
Old Sep 7, 2016 | 08:05 AM
FormerVendor
Time to get it done!
Old Sep 21, 2016 | 06:04 PM
FormerVendor
Heavy-duty, first-time-fit, and ready to go so you can get back on the trail!
Old Oct 18, 2016 | 02:58 PM
FormerVendor
Do it the right way.
Old Nov 1, 2016 | 08:20 AM
FormerVendor
Get those U bolts pointed the right way!
Old Nov 24, 2016 | 09:42 AM
FormerVendor
Get flipped!
Old Jan 5, 2017 | 06:48 AM
FormerVendor
Break out your jack, wrenches, and elbow grease to get this job done!
Old May 12, 2018 | 07:43 AM
FormerVendor
Turn that square frown upside-down and make it round!
Old Sep 7, 2018 | 01:57 PM
FormerVendor
Ground clearance and less headache for you!
your-real-dad
Engine Swaps
Feb 24, 2016 10:44 AM
medicmoose
Feb 14, 2016 09:05 AM
vikecowboy
Feb 9, 2016 07:31 AM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
