Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Toyota 8" Back Truss!
Old Jun 6, 2016 | 07:10 PM
Gravel Maker's Avatar
FormerVendor
Here we are, along the same lines of all our Crowned Trusses. This is the truss all Toyota guys have been waiting for!
This one, just like all of ours is shaped for maximum strength. The Crowned back will help keep your axle straight for years to come and if you combine it with the top truss you can feel free to jump it!
The truss is made from 3/16" steel and the fill hole access port completely protects the plug. They are meant to be welded full length. Start in the middle with 4" welds on top and bottom then heavy tack it everywhere. Then work from the outside in with 3" stitches alternating top to bottom until done.
These are setup to reach the full width of the axle housing on mini-truck axles, which is ideal for those who are going with links, and don't need a spot for the U bolts and perches. However we do send you an end cap that is left extra tall, so if you don't want the truss to go full width, then you can trim is shorter and the end cap still has the meat left to work with.
These are slightly thicker than the housing and will definitely make that axle last til you are ready!
Toyota Mini Rear Back Truss - RuffStuff Specialties
Old Jul 6, 2016 | 02:52 PM
FormerVendor
Give your stock housing some more beef!
Old Sep 15, 2016 | 04:04 PM
FormerVendor
Make the axle last a hell of a lot longer!
Old Sep 20, 2016 | 11:30 AM
FormerVendor
Armor it up before you bend and bash it beyond all recognition
Old Oct 3, 2016 | 07:57 AM
FormerVendor
Can be notched for U bolts, or works great with linked setups!
Old Oct 14, 2016 | 08:12 AM
FormerVendor
Give your housing the backbone it needs to handle your lack of driving ability! ;-)
Old Nov 1, 2016 | 08:20 AM
FormerVendor
Extra support for extra skinny pedal!
Old Nov 20, 2016 | 04:02 PM
FormerVendor
It is time to make your axle strong enough!
Old Nov 28, 2016 | 06:40 AM
FormerVendor
Full width if you can manage it, but we give you the pieces to trim it down shorter if you need to!
Old Jan 13, 2017 | 09:12 AM
FormerVendor
The best way to make your housing stand up to the test of time!
Old Mar 14, 2017 | 07:32 AM
FormerVendor
Make it more stronger!
Old Jun 30, 2017 | 02:46 PM
FormerVendor
Want your axle to last through the abuse ahead of it?
Old Jan 9, 2018 | 06:53 AM
FormerVendor
Give it a backbone!
Old Sep 13, 2018 | 02:25 PM
FormerVendor
The best way to make your 8" axle a beast!
