Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
New Products for FJ80s from Trail-Gear
Old Oct 1, 2012 | 08:28 AM
Trail-Gear's Avatar
FormerVendor
Trail-Gear has just expanded its product line to offer more great products for the FJ80 crowd. In addition to the new steering kits shown below the following existing products will work on FJ80s:
Hub Stud Kit (140438-1-KIT); http://www.trail-gear.com/hub-stud-kit
ARP 2000 Hub Stud Kit (144026-1-KIT); http://www.trail-gear.com/arp-2000-hub-stud-kit
Wheel Bearing Nut Kit (140424-1-KIT); http://www.trail-gear.com/wheel-bearing-nut-kit
Magnum Knuckle Studs (140171-1-KIT); http://www.trail-gear.com/magnum-studs
TG Super Metal Knuckle Studs (186116-1-KIT); http://www.trail-gear.com/super-metal-knuckle-studs
Knuckle Studs (140054-1); http://www.trail-gear.com/knuckle-stud-hardware
Knuckle Stud Nuts (140055-1); Knuckle Stud Wave Washers (140056-1); Knuckle Stud Cone Washers (140053-1), http://www.trail-gear.com/knuckle-stud-hardware
and most of the Trail-Gear recovery products. http://www.trail-gear.com/recovery
Old Oct 1, 2012 | 08:36 AM
MaK92-4RnR's Avatar
Finally someone brings out some FJ80 gear. You guys should look into tube doors for these things, if you go on Ih8mud there's some serious demand for them. No one makes a 4 tube door set for FZJ80s.
Old Nov 8, 2012 | 03:50 PM
Trail-Gear's Avatar
FormerVendor
Thank you for the suggestion! We will look into it.
Redeth005
Jun 28, 2018 08:16 PM
LCE_Performance
Oct 1, 2015 01:03 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
Ryall
Sep 2, 2015 06:48 AM
