Last edit by: IB Advertising
- Toyota 4Runner 1996-2002: Aftermarket Modifications
Overview of popular modifications to help you customize your 4Runner.
The most complete 3rd Gen 4Runner lift kit ever offered: Featuring Tundra TRD coils
All the details are here:
http://www.sonoransteel.com/store_co..._liftkits.html
The most complete 1996-2002 Toyota 4Runner lift kits available.
Every configuration has been thoroughly tested for years on trails like The Rubicon, In Moab - Utah, Colorado, Tellico and extensively in the rocky deserts of Arizona. There is not a more complete offering available anywhere.
System #1: The "All Toyota Factory Coil" lift: 2" Front & 3.5" Rear WITH a front mounted winch. The kit with the best "pure off-road" prowess bar none.
Front:
Toyota Tundra TRD 4WD Front Coil: Right Side - Blue + Yellow goes on the passenger side
Toyota Tundra TRD 4WD Front Coil: Left Side - Yellow + Yellow goes on driver side
Toyota 4Runner/Tacoma 4WD Front Shocks: Tokico Trek > Master R/T Green (TWO)
Sonoran Steel Fabrication L.L.C. Front differential drop spacers (TWO)
Sonoran Steel Fabrication L.L.C. 38mm Japanese made extended studs (SIX)
Bamachem 3/8" thick: 1/2" Lift HDPE Top Spacer (TWO)
Rear:
Toyota FZJ-80 Land Cruiser Coil: Right Side - Double Purple + Gray + White goes on the passenger side
Toyota FZJ-80 Land Cruiser Coil: Left Side - Green + Orange + White goes on driver side
Toyota FZJ-80 Land Cruiser stock rear shocks: Tokico Black (TWO)
Sonoran Steel Fabrication L.L.C. FJZ-80 to 4Runner rear shock discs (Four)
Sonoran Steel Fabrication L.L.C. Trac/PanHard Drop Bar, Special version sized to 3.5"
Sonoran Steel Fabrication L.L.C. Extended bump stop Adapters with Daystar KU09014BK Competition Style bump stops (TWO)
Sonoran Steel Fabrication L.L.C. Rear sway bar adjustment brackets (TWO)
Sonoran Steel Fabrication L.L.C. Braided Stainless Steel extended brake line or lines (1996-2000 one line, 2001-2002 two lines)
Sonoran Steel Fabrication L.L.C. Parking/Emergency Brake bracket (1996-2000 Only)
Shipping additional. All Brand New Parts.
System #1.5: The "All Toyota Factory Coil" lift: 2" Front & 3.5" Rear WITH a front mounted winch and Rubicon Express Super Flex Joint lower links. The kit with the best "pure off-road" prowess bar none. The rear Rubicon Express Super Flex joint rear links free the rear suspension up tremendously.
Front:
Rear:
Front:
Rear:
Front:
Rear:
Last edited by sschaefer3; Sep 25, 2006 at 05:55 AM. Reason: Updated for dual brake line 2001-2002, Added rear links
Originally Posted by SLC97SR5
Looks great Steve!! Just how much better are the Cruiser coils than the OME 891 with a 1"spacer? Added flex, softer on-road? Thanks!
System #1 Item Number for ordering = Nu-B X-Treme Lift
System #2 Item Number for ordering = Nu-B Lift
lol... good work steve. 'bout time somebody picked up where i left off and ran with this. looks like you have a source for the studs - great job on that - i hope my leads helped you out there...
bump for a good product from an even better guy.
Pretty awesome stuff Steve. I know that if I were to start over again, this is the route I would go. Plus getting your shaved a-arms.
I still love my OME890s though, perfect ride height, awesome flex, great street feel.
Awww, come on.....I may be a nu-b but jeez, do ya have to spell it out like that? Sweet package! (the parts, the parts)
Yep, props to Steve, he has been very helpful. I was having a terrible time trying to get all of the parts, and I saw on his site the whole thing. Sent him an e-mail and now everything I need is on the way in one box.
I think all i need is some limiting straps for the rear, but I am not going to be wheeling till summer, so those are going to wait i guess.
Originally Posted by Bighead
The stock stance has the back end about 1" higher than the front so it isn't really level to begin with.
Originally Posted by marko3xl3
So you are lifting the rear another 1.5" to make it less level? That's my question.
2" front and 3.5" rear are magic numbers. Things work really well at these numbers, that do not work so well at 2" front and 2.5" rear.
