Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
89-95 22RE/3VZE upgrade fuel injectors -free-
Old Apr 20, 2014 | 04:49 PM
Flame Thrower's Avatar
FormerVendor
hi all-
I am rolling out some new Bosch type 3 (0280155861) injectors modified to fit the 89-95 22RE and 3VZE engines.
I have done this before, and this will be the same deal as last time. I am giving out 10 sets of each to yotatech members with at least 50 posts for testing and evaluation purposes.
I need some "real-world" testing, and I am willing to send you a free set of custom 4-hole injectors for your honest evaluation of how well they work.
So send me a PM. Tell me a little about who you are; your mechanical aptitude; and tell me about your ride.
This should be fun.
Flamethrower
Old Apr 20, 2014 | 08:28 PM
Logger707's Avatar
I was planning on ordering a set for my 92' runner tomorrow.i need to replace a valve cover gasket and while it is apart I'm going to put upgrade injectors I don't have your required 50 posts so I will go the eBay route great to see someone willing to do something like this.too much greed out there
Old Apr 20, 2014 | 09:09 PM
Robert m's Avatar
Whats the difference between these and the ones you already sell?
And where was this deal 4 months ago when I bought some for my 22re?!?!?!
Old Apr 20, 2014 | 09:45 PM
Edionne13's Avatar
This may be a common question you get flame thrower but is it worth buying or as in acquiring yours or cleaning up my old stock v6 injectors out of my 93
Old Apr 20, 2014 | 11:22 PM
Blackulua's Avatar
Originally Posted by Flame Thrower
hi all-
This should be fun.
Flamethrower
PM sent
Old Apr 21, 2014 | 01:58 AM
chefdave's Avatar
Hi i have 50 posts can i trail a set. i live in the uk.have a slightly unusual toyota. it is a dolphin motorhome built on to a 1989 3 litre auto pick up chassis. Average mpg is 20 imperial. would these injectors improve low to mid range torque. as im not chasing top end power but a flat power curve. total weight of toyota is 2.8 tons and aerodyamics of a brick.
Old Apr 21, 2014 | 04:46 AM
Chaser Johndoe's Avatar
sent a pm
Old Apr 21, 2014 | 05:03 AM
nmtoy's Avatar
PM sent.
Old Apr 21, 2014 | 07:17 AM
FormerVendor
your stock injectors do an OK job. but having a better spray pattern makes a large difference in part-throttle driving, which is all most of us ever do.
your engine burns fuel vapor, not raw fuel. the closer the fuel is to vapor in the first place, the better. you get a bigger, harder bang with a cleaner burn that gives you more power and better throttle response. its not magic, it's combustion physics.
Old Apr 21, 2014 | 12:42 PM
Turbo_4runner's Avatar
Pm Sent!!!
Old Apr 21, 2014 | 12:44 PM
FormerVendor
they are going fast
edionne13 gets a set of 6
chefdave gets a set of 6
yotard gets a set of 6
crash813 gets a set of 6
Old Apr 21, 2014 | 01:07 PM
Robert m's Avatar
Old Apr 21, 2014 | 01:08 PM
Bradwv2001's Avatar
Sorry I don't have 50 post yet. But I am more than willing to try and write up about them. I have 86 4runner reman 22re with 12000mi. I drive it daily and will forever. If u don't want to send me a set that's fine but please at least pm me some ordering info. Thanks.
Old Apr 21, 2014 | 01:24 PM
I would also like ordering information because I'm putting together a turbo 3vze and in the process of tearing down the motor at the moment. I don't have 50 posts either but would like ordering information because my 4runner already runs on E85 currently but better flowing injectors would be a super asset once the turbo goes on in the next couple weeks.
Old Apr 21, 2014 | 01:29 PM
Guy I bought the truck from didn't tell me about any oil leaks, water leak, ect so I've been finding things out as i go that's been wrong but after I refresh her she should be all good! Won't let me attach any photos but I'll leave them in my album of the truck.
Old Apr 21, 2014 | 02:29 PM
Rowdydudeman's Avatar
bump for a good deal.
Old Apr 21, 2014 | 04:09 PM
87hoerunner's Avatar
PM SENT Great Opportunity for my new rebuild.
Old Apr 21, 2014 | 06:02 PM
Logger707's Avatar
Ordered a set this mornin
Old Apr 22, 2014 | 04:14 AM
junk4u's Avatar
Nothing for 84-87 22RE injectors?
Old Apr 22, 2014 | 07:46 AM
vasinvictor's Avatar
off-topic but PM me more about your planned turbo setup. I always thought it could work using the cold start injector for addition fueling on a boost switch. Or, of course, meth.
