Will a stock 82-83 tranny/engine hold up...
Old Jan 23, 2004 | 03:21 PM
LevZeppelin's Avatar
would a stock engine and tranny from an 83 or 82 be able to handle 35's and a lift or would you need to do a swap... also would it have enough power for crawling?
Old Jan 23, 2004 | 03:51 PM
toy283's Avatar
Should be fine. Gear down the diffs to 5.29's to get some of your power back.
Old Jan 23, 2004 | 07:05 PM
fourwd1's Avatar
Although the 83 tranny is a major POS (ask me how I know), if it's still working after 20 years you won't have a problem. Starting in 84 the trannys gradually were beefed up through the years.
Old Jan 23, 2004 | 09:17 PM
well if the 83 tranny is crap is there something that i can replace it with that isn't and will it be a fairly simple swap or would it be difficult.
Old Jan 24, 2004 | 08:09 AM
kyle_22r's Avatar
the most simple swap for this is also the most expensive. marlin of marlin crawler builds what he calls an L52-HD. it's basically an '83 style transmission with larger bearings and is supposed to be much stronger. i think it runs $799 + core though.
the option i'm probably going to do(albeit planning a 4.3 v6 swap as well) is putting a later series transmission under my truck. they are around 4" longer, so you will have to get your front driveline lengthened and the rear shortened. the R series is the strongest, they were used behind v6 and turbo trucks and can handle a 4.3 without problems. the W series is the next strongest, it was used behind EFI pickups from '85 up. the G series is better than an '83 transmission, but weaker than the other trannies
Team420
Dec 30, 2015 01:31 PM
RatOmeter
Oct 22, 2015 03:17 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
crashburnoveride
Jul 10, 2015 06:39 AM
