whats the downside in using driveshaft extensions
Old May 26, 2008 | 03:57 PM
pandaman's Avatar
whats the difference of either getting the extensions or justing getting a more heavy duty driveshaft
Old May 27, 2008 | 09:33 AM
Blizzard's Avatar
Well, using an extension causes your DS to be shorter so, worst U-joint angle. Other than this I cannot see another.
David
Old May 27, 2008 | 01:47 PM
4Crawler's Avatar
If your only issue is lack of length (i.e the overall shaft is too short), then an extension is an inexpensive way to extend a shaft:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
If the problem is that the slip yoke is not long enough (that is it can compress fully yet extends too far and separates), then the extension will not help, a longer slip yoke will be needed.
As noted, the angle on the driveshaft will be slightly higher with the extension, but not by much. For example on a ~24" long front shaft at a 20 degree angle, a 1" extension would add perhaps 0.8 degrees to the angle. The angle change will depend on the length and angle of the shaft and length of spacer used.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
matthew138
Sep 3, 2015 08:21 AM
