upper A- arm lift versus steering knuckle???
Old Nov 8, 2005 | 07:08 AM
Buck01's Avatar
I may have placed this in the wrong section earlier so I am reposting it here.
I want to lift my truck( 94 ). I want it high enough to fit at least 33's hopefully 35's. I am not looking for lots of wheel travel. This is my DD.
I don't want a harsh ride, again its my DD.
Don't want to spend a fortune. I have talked to Roger via email about ball joint spacers and shackles.
I have looked at several different lift kits.
The rear lift seems to be pretty standard using blocks.
The front lift seems to be done by either moving the upper control arm or changing the steering knuckle.
what are the pros and cons of each type of front lift?
here is an example of the steering knuckle kit.
http://cgi.ebay.com/ebaymotors/86-9...3 027764QQrdZ1
thanks for your input.
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000
MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit.
Old Nov 8, 2005 | 08:04 AM
deathrunner's Avatar
The steering knuckle does not add any travel, just lift. The ball joint spacer or an upper control arm actually gains travel.
Protrux is just a bout to finish thier upper control arm for 86-95 trucks and runners. it will add travel and allow you to use a quality shock, like a swaya away, king, or fox. It's gonna be a nice alternative to going full long travel. might want to give them a call about it. www.protrux.net
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
aowRS
Sep 13, 2017 08:22 AM
pickle6415
Dec 25, 2015 07:34 PM
crash813
Sep 27, 2015 07:15 AM
Project90
Sep 24, 2015 11:40 PM
