trd taco rear end?
Old Jan 28, 2004 | 04:29 PM
kyle_22r's Avatar
trd taco rear end?
i'm getting interested in getting a e-locker for my truck eventually. however, i'd also like a wider axle. i've heard that the tacoma with an e-locker has an 8" diff...i've found a few on car-part.com(more than i've found 4runner axles, and generally cheaper). i think they used 3.58 gears? is the the same old 8" diff as the 3rd gen 4runner with the locker?
Old Jan 28, 2004 | 07:42 PM
kyle_22r's Avatar
hmm...sounds interesting. that's why i was thinking about the taco housing, since it's already set up for leafs(not sure if the perches are spaced right though)
redoing the stud holes and modifications to a housing aren't out of my reach, and i'm second in line at an '85 front and '90 rear, both rebuilt for 250$. if i get it i'll just sell the front and keep the rear for my truck, and make back what i paid for it
Old Jan 28, 2004 | 08:39 PM
Napoleon047's Avatar
the tacomas and t100's have an 8.4" diff, although stronger, it doesnt have nearly the aftermarket support yet of the 8" axles (lockers, gearing, etc)
Old Jan 28, 2004 | 09:07 PM
RTdawgs's Avatar
tacomas with elocker have the 8" diff. (same as the 4Runner, early Toy V6 diff)
tacomas without the e-locker have the 8.4" diff. an ARB RD89 air locker is avail for that diff.
just for clarification.
Old Feb 11, 2004 | 05:19 PM
josh's Avatar
zesty
MOST e-locked taco's came with 4.10's. Some had 4.56's, and some had other weird things like 4.30's. Basically, if its a pre-01 axle it will most likely have 4.10's.
Old Feb 11, 2004 | 06:35 PM
toy283's Avatar
The Tacoma housing will bolt up to your springs just fine, with a few minor issues. Be sure to get the e-brake cable, u-bolts & plates, etc. from the Tacoma axle, yours won't work. Also, the bracket for the LSPV is on the opposite side, you will need to weld on a new one to hook up to your valve. The e-brake cable will also need to be reversed but it is a fairly simple task as well.
Jun 1, 2021 01:51 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
