torsion bar adjustments
Old Oct 28, 2006 | 10:11 AM
1stgenrnrdude's Avatar
i have a 1988 runner, and i just dropped it off at a shop.. i talked to guy that works there two days ago that has an 88 pickup and he said i should have no problem getting 2 inches of lift by adjusting the torsion bars.. i took it there yesterday and the guy that was working at that time said i was LUCKY if i was gonna get 1 1/2 inches of lift.. how much lift can i (safely) get by adjusting the torsion bars?-thanks
Old Oct 28, 2006 | 12:27 PM
millertime_t1's Avatar
1 1/2" - 2" But going that much you are putting your cv shafts at a much higher risk and your ride quality will suffer tremendously
Old Oct 28, 2006 | 12:43 PM
MonsterMaxx's Avatar
Yes, you can crank the stockers, but you are putting them under a lot of load by doing so and the truck will ride stiff.
Replace the stockers with heavy duty bars and the ride will be silky smooth again.
Also, cranking the ride up 1.5-2" increases CV angle, this wears the boots much more quickly. Manual hubs will solve that problem.
Also, by cranking them up that far you are about out of down travel. Get the low profile snubbers for the downstops and you'll get the additional down travel you need.
PS, just noticed there's a set of Downey HD torsion bars on fleabay
http://cgi.ebay.com/ebaymotors/downe...spagenameZWDVW
Old Oct 28, 2006 | 03:48 PM
thank both of you. i already have manual hubs.. yeah im lookin to do 2 in. in the front and 2in. shackles in the back. thanks guys
Old Oct 28, 2006 | 09:21 PM
tc's Avatar
tc
Do a search for "ball joint spacers". Only way to lift and maintain the suspension travel/ride.
Old Oct 29, 2006 | 01:27 PM
4Crawler's Avatar
Ball joint spacers are a good option, you get most of the lift from the spacer and if you need a little more out of the torsion bars, you can crank them up a little. Keeps the ride quality decent and improves the wheel travel up front:
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
You can also add a diff. drop kit if the CV joint angles get too severe:
- http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Old Oct 29, 2006 | 01:34 PM
AH64ID's Avatar
Not really true. I have 25mm PowerBarz and they are stiffer than stock, and even with my ARB and winch and the bars as loose as I can get it I am about 1" over stock, and its a stiffer ride.
BJ spacers are the way to go.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
choppe777
May 16, 2016 08:00 AM
Scottcrb
Mar 3, 2016 11:57 AM
HiLuxer
Sep 9, 2015 02:43 PM
moparbay
Sep 3, 2015 12:48 PM
