Tire Chains for a 37"? Rec's?
Old Nov 22, 2010 | 11:06 PM
drew303's Avatar
Ideas guys?
I emailed tirechains.com. I saw what they had on the site for a 37 but not sure about that rubber tensioner or the cams, lil confusing.
Last set of chains i had were for my 31" i got from Les Schwab and i ended up breaking one up int he mtns on a nasty road. Overall I didn't like those style quick fit chains schwabs sell. Real weak links and they arent any faster to install, if anything more of a pain in the butt.
thx
Old Dec 2, 2010 | 04:57 PM
nothingbetter's Avatar
you could always make your own. Then they can be as strong as you want. Use some quick links for connectors and those un-fancy rubber straps as a tensioner and off you go!
Old Dec 2, 2010 | 05:10 PM
MaK92-4RnR's Avatar
question, whats the benefit of chains on a mud terrain? never really seen anyone use them. so im assuming same benefit as any other tire?
Old Dec 2, 2010 | 05:14 PM
they most likely won't be used in a mud situation, more so in deep snow and ice where a MT won't have very good traction.
Old Dec 2, 2010 | 05:22 PM
MudHippy's Avatar
Chains work just as well in the mud as they do in the snow(if not better). Chains will take you WAY farther than your MTs will, even if they're boggers, mud or snow. As far as ice, there's nothing better than a good set of chains. Unless you put some serious tire studs on, not the kind they put on at the tire store BTW. I'm talking some that stick out further from the tire and in much higher numbers. Like they use for ice racing.
Old Dec 2, 2010 | 05:36 PM
MaK92-4RnR's Avatar
lol how much are chains for a 33 though?
Old Dec 2, 2010 | 05:52 PM
MudHippy's Avatar
You won't be laughing at this.
$84-$250 for a good pair(2 tires). Depending which you type want. And you DON'T want the cheap ass cable type.
http://www.tirechain.com/33x12.50-15.htm
Old Dec 2, 2010 | 05:54 PM
MaK92-4RnR's Avatar
tire chains wont knob off the tread on tires either? i wonder how much they are for my 33x10.50s
lol the rules to the CA Chain requirements has a 4Runner in it
http://www.dot.ca.gov/dist3/departme...ireschains.htm
Old Dec 2, 2010 | 07:00 PM
EDIT: In my previous post I intended to say that it didn't sound like chains were going to be used for mud in the praticular situation.
Mak92. If you have your chains on for a long time then they will wear your tires a bit where they contact. Constant rubbing is never a good thing. But just putting them on now and then won't cause any major issues.
Old Dec 2, 2010 | 07:13 PM
MudHippy's Avatar
Originally Posted by MaK92-4RnR
...i wonder how much they are for my 33x10.50s
Slightly less, $60-$236 per pair. http://www.tirechain.com/33X10.5-15.htm
Old Dec 2, 2010 | 07:34 PM
MaK92-4RnR's Avatar
lol hmm... i might have to look into this! are they much of a difference in snow/mud? Do they make a difference in sand?
Old Dec 2, 2010 | 08:00 PM
MudHippy's Avatar
Mud/snow, put a pair on the rear and you'll hardly ever need to shift into 4WD.
Sand, don't do it. Don't even do MTs. Anything that's going to dig is only gonna get you buried. Just air down and pray.
Old Dec 2, 2010 | 08:06 PM
MaK92-4RnR's Avatar
I went to the Pismo jamboree and my truck was a blast. i have KM2s, just air'd down and called it good
Old Dec 3, 2010 | 12:08 AM
drew303's Avatar
I ran Les Schwab chains on all 4's for a number of years and finally broke a cross link on one tire in the mountains.. they made a difference in most situations but i was never impressed.
Im holding off on buying a set as of right now, weathers holding out =P and im investing $ into the truggy instead... really need a front drive shaft more than i do chains but its all good to know anyway!
Old Dec 3, 2010 | 08:49 AM
OrRunner's Avatar
just pick up a set of cam locks from schwabs, with tensioners for $80. I have never had a problem with them, the cable type suck. These will fit a number of differant size tires, and are marked to fit 33x10.5x15
Op-
You may look into a set of chains from a Semi truck supply store, I have a buddy who gets used cam lock from trucking company here for dirt cheap, cut them down to what you need them to fit and your good to go..Should def fit a 37 with minimal trimming required
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
raiderhawks00
Jul 8, 2015 06:23 PM
